Wheel sizes for 370Z
stu1986
Hi all
I am looking at getting the following wheel sizes would these fit right on my 370Z? I dont fancy paying out and then not seeing them fitting correctly
20x 9.5 - Fronts
20x 10.5 Rears
Also what other things should I be aware of when ordering wheels?
Thanks in advance
Stu
I'm pretty sure you can fit R35 GT-R wheels to a 370Z without problems and they're the same sizes you're talking about with offsets of ET45 front, ET25 rear. As 350Ad said, make sure the PCD is 5x114.3 and the centre bore needs to be at least 66.1mm (if larger you'll need hub rings). Then you just need some suitable nuts (the 370Z Rays use a flat seat nut which is different to most aftermarket wheels) and tyres, I would guess something like 255/35R20 front, 285/30R20 rear but you might want to check what others have tried.
I'll give the company a call and ask the following questions then
What are the offsets?
What's the PCD?
Centre Bore Sizes?
Sorry about this guys just I have never chosen a set of wheels really before usually I just get them from someone who's used them before but the set I want now I just wanted to make sure they fit properly :)
