_BR1TT0N_ Posted December 17, 2013 Share Posted December 17, 2013 Hey Guys! My passenger window stopped working after picking it up from the body shop! Thought it would probably be the window motor. Just swapped the window motor over and still doesn't work. Can someone help me with any other steps to check? Thanks Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 17, 2013 Share Posted December 17, 2013 Check the window lock switch on the driver's door. Alex. Quote Link to comment Share on other sites More sharing options...
Grundy Posted December 17, 2013 Share Posted December 17, 2013 If it's that ^^...... Quote Link to comment Share on other sites More sharing options...
Dicky Posted December 17, 2013 Share Posted December 17, 2013 As Alex suggests check obvious problem areas first eg operating switches, wires hanging off, blown fuse etc If none of these then sounds like you've lost the 12v supply to it . Confirm by using a multimeter, set to dc volts, and clip the leads to the motor connections. Operate the window, you should read 12v. If not it's fuse checking time, locate and test with multimeter. If fuse ok then it's wiring diagram time. Using the car body metalwork as neutral or earth test the live connection from origin at points on its journey to the motor you should read 12v at each test point when the window switch is operated.Probably best to go to a half way point first so if you get 12v you've halved your work. If it was working before the body shop visit take the matter up with them. Quote Link to comment Share on other sites More sharing options...
_BR1TT0N_ Posted December 17, 2013 Author Share Posted December 17, 2013 Thanks for your replies guys! Right I installed a new motor and that didn't work either! Checked voltage and there is power going to the switch but no power going to the motor. Does this mean it's the switch? Also when I push the little button on the door shut, the drivers side window goes up to seal but still this passenger window doesn't move. What do you guys recon? Quote Link to comment Share on other sites More sharing options...
