Genuine Nissan Compression Arms 350Z, £250 per side
Ewen@Clark Motorsport
A fresh delivery has just arrived of genuine Nissan compression arms. These are a common failure and retail at £300 from a Nissan dealer.
Beware of cheap aftermarket arms the quality is not the same.
We have loads in stock and they can be found here:
Left hand side http://www.clarkmoto...eft/54469-CD00C
Right hand side http://www.clarkmoto...ght/54468-CD00C
It is also recommended that you fit a new ball joint seating cone and retaining nut, they can be found here:
Cone http://www.clarkmoto...one/40173-33P00
Nut http://www.clarkmoto...Nut/01225-00941
If your ball joint is ok and its only the bush that is worn we can supply OEM Nissan bushes not available from Nissan in the UK for only £29.99, they can be found here http://www.clarkmoto...ush/54570-AC70A
Visit our online shop for a huge range of 350Z and 370Z parts http://www.clarkmoto....uk/Home/1.html
Edited by Clark Motorsport/Zmanalex
