Ian Posted June 24, 2007 Share Posted June 24, 2007 Since installing my Decat pipes earlier this year I have had the CEL on. I fitted the Non foulers & did the reset with the pedals - This usually lasted about 50/60 miles until the CEL returned. I recently bought an OBDII scanner and Digimoto software. I checked the codes & all 4 related to the 02 sensors. Since resetting my ECU using Digimoto I've done about 700miles & have not seen the CEL return. Is the pedal reset anything more than a temporary fix? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 24, 2007 Share Posted June 24, 2007 It's a proper reset but if you have a problem then it will re appear as it should do. I thought this is what happens anyway when decatting. Sorry don't know if there is a fix but someone on here will Quote Link to comment Share on other sites More sharing options...
Ian Posted June 25, 2007 Author Share Posted June 25, 2007 It's a proper reset but if you have a problem then it will re appear as it should do. Thats my point, When I reset using the pedal reset it always came back on, since using the software and code reader to do it im running decats with no issues Was just wondering why its ok now if the resets are the same Quote Link to comment Share on other sites More sharing options...
Pingu2 Posted June 25, 2007 Share Posted June 25, 2007 they arent the same? the obd-ii is only resetting the CEL light and not the ECU (ie not the fuel trims etc).. to reset the ecu fully via the diagnostic port you need nissan consult or similar? Quote Link to comment Share on other sites More sharing options...
sl114 Posted June 25, 2007 Share Posted June 25, 2007 Strange as if there is a problem, when the ECU does it checks (every X miles) it will read a fault with the O2 sensors and flick the warning light on. The ECU flash should not change this no matter which way you do it. How many times have you done the foot pedal technique? The only way to fully get this turned off will be to put in a MIL eliminator i think, thats if its the same as my old car. Quote Link to comment Share on other sites More sharing options...
Pingu2 Posted June 26, 2007 Share Posted June 26, 2007 if you just reset the MIL light without resetting the fuel trim, maybe the O2 sensor stays within range? Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted June 26, 2007 Share Posted June 26, 2007 For the record the ECU 'does its checks' several hundred times per second Ian, you have got your car into a stable state with test pipes by whatever means - cross your fingers and hope it stays that way Quote Link to comment Share on other sites More sharing options...
Ian Posted June 26, 2007 Author Share Posted June 26, 2007 Strange as if there is a problem, when the ECU does it checks (every X miles) it will read a fault with the O2 sensors and flick the warning light on. The ECU flash should not change this no matter which way you do it. How many times have you done the foot pedal technique? The only way to fully get this turned off will be to put in a MIL eliminator i think, thats if its the same as my old car. I was doing the pedal technique atleast once a week. Im crossing fingers, toes and anything else I can that it stays this way Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted June 26, 2007 Share Posted June 26, 2007 Not every code throws the CEL of course Quote Link to comment Share on other sites More sharing options...
