:RedZed: Posted December 3, 2013 Share Posted December 3, 2013 I'm trying to locate a rattle coming from the engine bay. The noise appears to come from the back of the engine if you were to be looking at it from the front of the car, where you would normally see the exhaust manifold in a 4 pot. What's back there? Anything that could come loose or need replacing with age? Thanks! Quote Link to comment Share on other sites More sharing options...
daveparkin Posted December 3, 2013 Share Posted December 3, 2013 Fuel pressure dampers 1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted December 3, 2013 Share Posted December 3, 2013 Gearbox? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted December 3, 2013 Share Posted December 3, 2013 the car....? 2 Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted December 3, 2013 Share Posted December 3, 2013 The nut loose behind the wheel.. :blush: Quote Link to comment Share on other sites More sharing options...
Paddy78 Posted December 3, 2013 Share Posted December 3, 2013 Probaby the central fuel pressure regulator. Nothing to worry about. You can tell if it's this by touching it and it will be vibrating in time to the rattle. Quote Link to comment Share on other sites More sharing options...
leonk Posted December 3, 2013 Share Posted December 3, 2013 Does it go when you dip the clutch? Quote Link to comment Share on other sites More sharing options...
Daryl Posted December 3, 2013 Share Posted December 3, 2013 I had a strange rattle sound coming from what I thought was the dash, or at the back of the engine. Replaced the Y pipe and Cats, and the rattle has gone. Maybe its one/both of these, though I hope for your sake not. Quote Link to comment Share on other sites More sharing options...
leonk Posted December 3, 2013 Share Posted December 3, 2013 I had a strange rattle sound coming from what I thought was the dash, or at the back of the engine. Replaced the Y pipe and Cats, and the rattle has gone. Maybe its one/both of these, though I hope for your sake not. As above, heat shield shields on top of the cats could be a possibility. Quote Link to comment Share on other sites More sharing options...
rothers2901 Posted December 4, 2013 Share Posted December 4, 2013 Heat shields sounds the likely source Quote Link to comment Share on other sites More sharing options...
:RedZed: Posted December 4, 2013 Author Share Posted December 4, 2013 Thanks for the suggestions. I'll have a look and report back. Quote Link to comment Share on other sites More sharing options...
Daryl Posted December 4, 2013 Share Posted December 4, 2013 Well i ripped both heat shields off, and still had the rattle, was only replacing them that got rid of the noise. Quote Link to comment Share on other sites More sharing options...
