Has anyone fitted high-lift cams?
Space Cadet
Quite fancy keeping the Z normally aspirated, have had a few turbo’d cars and fancied a change with the Z, anyway have messed around with cams in the past on NA cars and if it’s set up properly can be wicked.
It seems to be the trend on the site to go down the supercharger or turbo route but has anyone fitted for example the Nismo cams or any others?
Thanks.
Guest prescience
The main problem being how do you tune for them - presumably (but I do not know) if you just did cams, you would get all kinds of warning lights if you had no standalone or piggy-back EMS in tandem :)
If the cams are not too extreme then the standard ECU normally works ok.
Poor example I know, but with my first car a Saxo VTS it was happy with some mild cams (and pulley wheels), with approx. 20% increase in BHP (But with gradually higher lift cams the car would be virtually undrivable until I needed a stand-alone ECU and end saw approx. 60%, but with a full engine build).
Nismo do various cams for the Z and with an experienced garage I wondered if it would be fun having a mild set put in, I think the car feels a bit lethargic, I don’t mean lacking in power but needs it to rev more and more freely.
Anyway, just wondered if anyone else had fitted cams rather than going forced induction which I don’t want to do.
