Desey Posted December 1, 2013 Share Posted December 1, 2013 Hi all Have a 04 JDM Z with non brembo brakes when buying i thought the standard brakes would be good enough. turned out they sucked changed to yellowstuff pads and slotted discs and the braking is now great, but the abs at times comes in way too early but i know theres way more brake force that could be applied im running Rota GTR-D 18"s with 235/45 front and 255/45 rear and -1.5 camber on the rear is there any way to adjust the abs without ecu mapping or whatever or disable the abs? Quote Link to comment Share on other sites More sharing options...
Commander Posted December 1, 2013 Share Posted December 1, 2013 Surely the ABS kick-in point is determined by the ABS Sensors that are in the hubs and the ABS ECU? In which case changing the brakes, tyres, whatever, shouldn't have an adverse affect at all? As soon as the sensor detects some under-rotation of the wheel, it kicks in, regardless. I'd have thought that short of modding the ABS Sensors / ECU, the only way to have a greater rate of deceleration before ABS kicks in is to have more grip? Better tyres, different pressures, etc? Quote Link to comment Share on other sites More sharing options...
Neilp Posted December 1, 2013 Share Posted December 1, 2013 I'm not sure but I think it's your tyre sizes that are causing it. I do a calculation online to check the rolling radius difference from oem Quote Link to comment Share on other sites More sharing options...
