Hammerz Posted November 30, 2013 Share Posted November 30, 2013 Hi, I've got a problem with possibly both window motors failed on my new Zed. I attempted to carry out the clean first to see if that helps but at the stage of the guide where I put the window down to remove the bolts in order to remove the glass I couldn't get it to move at all. Not being able to remove the glass meant I couldn't remove the internal part of the door and couldn't progress to removing the motor for cleaning. I'm fairly sure the previous owner has already attempted this because it looked like the door card had been removed before so I'm going to have to buy new motors but how will I fit them if I can't remove the glass? As always help is much appreciated! Also, when buying the window motors any hints at other things to replace/upgrade (speakers?) or anything from the trader that'd be good to get at the same time (car is relatively standard). Cheers Quote Link to comment Share on other sites More sharing options...
KyleR Posted December 1, 2013 Share Posted December 1, 2013 You don't have to remove the window, just get a mate to hold it up or you can also use duct tape. Quote Link to comment Share on other sites More sharing options...
Hammerz Posted December 1, 2013 Author Share Posted December 1, 2013 Isn't it attached to the mechanism so I can't remove the inner door card that has 12 bolts? Quote Link to comment Share on other sites More sharing options...
KyleR Posted December 1, 2013 Share Posted December 1, 2013 I think 2 or 3 of the bolts in the metal door panel are attached to the mech, but there are more on the other side holding the glass to the mech, so by holding the glass up, you'll be holding the mech up and the window won't fall and you can access the motor. Quote Link to comment Share on other sites More sharing options...
richmillions Posted December 1, 2013 Share Posted December 1, 2013 I replaced the motor a few weeks ago and didn't remove the glass. Quote Link to comment Share on other sites More sharing options...
Jixaman Posted December 2, 2013 Share Posted December 2, 2013 Glass is a doddle... Drop it down till the three bolts can be seen and removed through the holes in the metal sheet (12 bolts), remove glass, remove 12 bolts, rebove metal sheet... Really, so so easy and simple... Oh and dont think its going to be a nightmare puting it all back together, the design is idiot proof (no offence to anyone) the bolts go through the glass so it really only can go in one way, I done mine all on my own, probably better with 2 but it can be done... Quote Link to comment Share on other sites More sharing options...
Hammerz Posted December 2, 2013 Author Share Posted December 2, 2013 How can you drop it down when the motor doesn't work? Haven't had chance to have another go since my first post Quote Link to comment Share on other sites More sharing options...
Jixaman Posted December 3, 2013 Share Posted December 3, 2013 Oooops, obviously didnt read that right... Sorry... But, if you do get it down, the above still stands... Hope you get it fixed, you so easily take for granted windows that open till you dont have them... Cheers... Quote Link to comment Share on other sites More sharing options...
