R34Nigel Posted November 30, 2013 Share Posted November 30, 2013 Hi, My car had the UpRev installed by the previous owner and before I had it the car had De-cat pipes fitted. My question is, when I refit the De-cat pipes will I need to transfer the O2 sensors from the cats or are they usually disabled when flashed? Thanks Quote Link to comment Share on other sites More sharing options...
Richf Posted November 30, 2013 Share Posted November 30, 2013 From what I understand there are two sensors each side so four, the regular O2 ones which sit before the cat and two that sit after the cat and measure its efficiency , it's these sensors that are troublesome setting off cel lights etc and these are the ones disabled during up rev. So cats or no cats won't make any difference Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 30, 2013 Share Posted November 30, 2013 You can actually run with the cat monitor lambdas removed even without up-rev, you will get cel but that's it, I replaced mine with wide-band sensors. Quote Link to comment Share on other sites More sharing options...
R34Nigel Posted December 1, 2013 Author Share Posted December 1, 2013 I have unplugged the back two and no error lights so I guess it will be fine Quote Link to comment Share on other sites More sharing options...
