Idle relearn procedure what does it do?
Richf
Had an issue where the rpm was hanging at 1500-1600 when coming to a stop and that idle was around 1100rpm .
So did the throttle pedal reset, throttle valve reset and then the idle relearn , all worked great idle now is 750rpm or so .
But
The car drives much differently , feels like some ignition timing has been added , the car picks up easier and seems to rev cleaner
Really wasn't expecting this so feels like a full ecu reset but is that what happened ?
I am pretty sure that idle relearn also clears short term fuel and timing trim, so you will notice a difference if you have been doing say commuting for the last few days, or running lower octane fuel, the ECU will adjust the trims to suite how you drive, so clearing them will often be noticed.
