Supercharger/ Twin Turbo on an Automatic
N9JAH
I had a 7AT and done quite a bit of research on it from various forums. It can handle the power up to 4th gear. After that the clutch packs are too small and will fail eventually. An expierenced Uprev tuner will also need to increase the line pressures to each gear so they do not slip as much. The only other thing I would pair with it is a Tranny cooler. Valve body and torque converter if your going for over 500WHP but much more than that I would be worried about the motor as well.
