370Ad Posted November 21, 2013 Share Posted November 21, 2013 (edited) Just thought I would make this post as an FYI to anyone who needs their compression arm bush replaced. You can get a genuine one for around (Exchange rate dependant) £22 delivered from an Infinity garage in the states. I ordered mine on the 13th and it arrived yesterday so 7 day turn around. http://www.ebay.co.u...984.m1439.l2649 eBay store if link goes dead: http://www.ebay.co.uk/usr/ocinfiniti $19.95 + $15 USPS delivered, tracked to your door. I know there have been posts about a none genuine one appearing for £30 on eBay so this is a much better bet. Since the value of the item is so low there is no import duty to pay. Hope this helps someone out EDIT - Looks like they have added a quicker shipping method to the listing which is quite expensive. Ask the guy for a USPS First Class quote as that what I got for $15. Edited November 22, 2013 by 350Ad Quote Link to comment Share on other sites More sharing options...
Tinyflier Posted November 22, 2013 Share Posted November 22, 2013 Wow that is an amazing saving over OEM UK part price. I'll be investigating tonight! David 1 Quote Link to comment Share on other sites More sharing options...
yorkshire Posted November 22, 2013 Share Posted November 22, 2013 Are the bushes easy to change over? Mine is knocking terribly and was saving up to buy a whole new arm Quote Link to comment Share on other sites More sharing options...
SamN Posted November 22, 2013 Share Posted November 22, 2013 As I mentioned a while ago mine is knocking quite a bit. I'm not sure if it's the bush or ball joint though need to find some time to remove the arm and investigate! I'll keep an eye on this though as that's a great price! Quote Link to comment Share on other sites More sharing options...
370Ad Posted November 22, 2013 Author Share Posted November 22, 2013 (edited) On 22/11/2013 at 07:51, yorkshire said: Are the bushes easy to change over? Mine is knocking terribly and was saving up to buy a whole new arm You need quite a strong press so its usually a garage job. Job time is an hour so all depends on the garage rate. On 22/11/2013 at 08:56, SamN said: As I mentioned a while ago mine is knocking quite a bit. I'm not sure if it's the bush or ball joint though need to find some time to remove the arm and investigate! I'll keep an eye on this though as that's a great price! Get underneath mate as you can usually tell if its the bush as the compression arm has moved or the rubber from the bush is sticking out of the metal sleeve. Edited November 22, 2013 by 350Ad Quote Link to comment Share on other sites More sharing options...
SamN Posted November 22, 2013 Share Posted November 22, 2013 Is it easy to see? I assumed I'd have to move a couple of bits. I'll have a look when I can. Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted November 22, 2013 Share Posted November 22, 2013 If you need the bush next day we have dozens in stock for next day delivery if ordered before 3PM at £29.99 inc VAT. http://www.clarkmotorsport.co.uk/parts/Compression-Rod-Bush/54570-AC70A Quote Link to comment Share on other sites More sharing options...
370Ad Posted November 22, 2013 Author Share Posted November 22, 2013 On 22/11/2013 at 10:01, SamN said: Is it easy to see? I assumed I'd have to move a couple of bits. I'll have a look when I can. Really easy to see. TBH you don't even need to get underneath you can usually see on the flat with the wheel turned. Quote Link to comment Share on other sites More sharing options...
Tinyflier Posted November 22, 2013 Share Posted November 22, 2013 On 22/11/2013 at 10:19, Clark Motorsport/Zmanalex said: If you need the bush next day we have dozens in stock for next day delivery if ordered before 3PM at £29.99 inc VAT. http://www.clarkmoto...ush/54570-AC70A OEM or pattern? Pair or single? David Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted November 22, 2013 Share Posted November 22, 2013 On 22/11/2013 at 10:47, Tinyflier said: On 22/11/2013 at 10:19, Clark Motorsport/Zmanalex said: If you need the bush next day we have dozens in stock for next day delivery if ordered before 3PM at £29.99 inc VAT. http://www.clarkmoto...ush/54570-AC70A OEM or pattern? Pair or single? David That's for Genuine OEM Nissan and that price is a single bush Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted November 22, 2013 Share Posted November 22, 2013 Its is also advisable to change the seating cone at the same time http://www.clarkmotorsport.co.uk/parts/Compression-Rod-Cone/40173-33P00 We also supply fitting instructions as if fitted incorrectly you will have alignment issues 1 Quote Link to comment Share on other sites More sharing options...
