SamN Posted November 20, 2013 Share Posted November 20, 2013 So I just started to remove my centre console and got to the bolt on the driver side next to the seat and my seat (electric) will tilt forward/back but won't slide!! After a bit of research people say remove the seat and take the motor apart, well the seat is as far back as it'll go so I can't remove it! Any ideas where to start?? Thanks Sam Quote Link to comment Share on other sites More sharing options...
coldel Posted November 20, 2013 Share Posted November 20, 2013 You mean when you flick the switch it wont move? First port of call are bad terminals, try a bit of WD40 and tap the top of the switch for about 20-30 seconds, it might just be the connectors and this will start it up again (well it did with mine!) Quote Link to comment Share on other sites More sharing options...
SamN Posted November 20, 2013 Author Share Posted November 20, 2013 Yep exactly that. Just tried WD40 and no luck Quote Link to comment Share on other sites More sharing options...
GMballistic Posted November 20, 2013 Share Posted November 20, 2013 Had a similar issue with my drivers seat before I bought my Zed. It was tilted/slid all the way back & wouldn't move. The dealer fiddled with the switch back & forth for several minutes before it eventually moved forward just enough for me to reach the peddles to test drive it. He said not to worry though as it was probably just a bad connection and they'd sort it before I picked up the car. Well in the end it needed a complete new switch unit which they bought from Nissan & fitted at there cost. Works perfectly now obviously. You may well end up needing a new switch if it's not just a connection issue. Quote Link to comment Share on other sites More sharing options...
SamN Posted November 20, 2013 Author Share Posted November 20, 2013 Balls.. No quick fix then Quote Link to comment Share on other sites More sharing options...
GMballistic Posted November 20, 2013 Share Posted November 20, 2013 Balls.. No quick fix then If you've tried what Coldel suggested and made sure all the connections are good/plugs in situ etc then possibly not. If you pull the electric seat switch backwards & forwards repeatedly will the seat move at all? show any signs of life? If not then you may well need a new switch unit as I did unfortunately. Quote Link to comment Share on other sites More sharing options...
SamN Posted November 20, 2013 Author Share Posted November 20, 2013 Well if I tild forward and press slide back at the same time, the tilt becomes slower but that's all.. Otherwise nothing. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted November 20, 2013 Share Posted November 20, 2013 Well if I tild forward and press slide back at the same time, the tilt becomes slower but that's all.. Otherwise nothing. Could be FUBAR then. Maybe wait and see if anyone else on here has any ideas. Quote Link to comment Share on other sites More sharing options...
onthatB0MBSHELL Posted November 20, 2013 Share Posted November 20, 2013 I had the same problem with my driver seat, for months it was a matter of pushing back and forward until it eventually started, really was a nuisance as the driving position difference between me and Mrs made it impossible for me to get into the car. I had enough one day and removed the whole seat assembly, removed the whole switch mechanism and gave the whole unit a clean down with WD40, amazing the amount of grime gathers down in there. That was months ago and it has preformed flawlessly since. Hope you sort it, bit of time and elbow grease required. Quote Link to comment Share on other sites More sharing options...
SamN Posted November 20, 2013 Author Share Posted November 20, 2013 Cheers. I'm happy to remove the seat and then the motor etc to clean it all up, I just can't get to the rear seat bolts! I also noticed my seat belt seems to be slightly loose which is more of a concern! Want to get the seat out to tighten that up too! Quote Link to comment Share on other sites More sharing options...
SamN Posted November 26, 2013 Author Share Posted November 26, 2013 Interesting, it started working on it's own by pressing the button a bit harder. Quote Link to comment Share on other sites More sharing options...
coldel Posted November 26, 2013 Share Posted November 26, 2013 Just some crap on the connectors, all the fiddling probably loosened it and boom, one happy motorist. This happens a lot on the Zed, sticky? Quote Link to comment Share on other sites More sharing options...
jumping350 Posted November 26, 2013 Share Posted November 26, 2013 (edited) Could be a sign of the switch on its way out, the same was happening to mine all buttons to me seemed fine but at garage they said switch was knackered eventually got some switches and hey presto worked perfect ever since Edited November 26, 2013 by jumping350 Quote Link to comment Share on other sites More sharing options...
SamN Posted November 26, 2013 Author Share Posted November 26, 2013 I may remove the whole switch assembly at some point and clean it all up, that should prolong their life a bit Quote Link to comment Share on other sites More sharing options...
GMballistic Posted November 27, 2013 Share Posted November 27, 2013 ^^Sounds like a good plan. Glad it's working again for you now in the mean time. 1 Quote Link to comment Share on other sites More sharing options...
