Dashurik Posted November 20, 2013 Share Posted November 20, 2013 (edited) Bought full set Falken 453 tyres month ago(rears:275/35/19, fronts:245/35/19)..Good grip wet or dry. Personally I think these tyres are harder material than my previous ones(back: continental front: fullrun). I can feel every possible bump on the road.Also,it might be mechanical issue,noticed that its harder to control my steering wheel.May be tyres are heavier than old ones and that's reflecting my drive .Wheels were balanced when fitted but I didn't do realignment on HUnter system. IF I will be in ownership of my vehicle in few years time I will definetelly put softer tyres. Edited November 20, 2013 by Dashurik Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted November 20, 2013 Share Posted November 20, 2013 I run mine at 30 to 32 psi instead of 35 psi, makes a vast difference to the ride. Quote Link to comment Share on other sites More sharing options...
firemansim Posted November 20, 2013 Share Posted November 20, 2013 I run mine at 30 to 32 psi instead of 35 psi, makes a vast difference to the ride. I do the same with my Falkens Quote Link to comment Share on other sites More sharing options...
Dashurik Posted November 20, 2013 Author Share Posted November 20, 2013 I run mine at 30 to 32 psi instead of 35 psi, makes a vast difference to the ride. Thanks for advise,I ll do so ,see if that will change the ride! How is your steering wheel control? Was it different feel after you fitted your new tyres ? Found mine is slightly different ! Hopefully running tyres on lower psi will sort it out.. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted November 20, 2013 Share Posted November 20, 2013 I run mine at 30 to 32 psi instead of 35 psi, makes a vast difference to the ride. Thanks for advise,I ll do so ,see if that will change the ride! How is your steering wheel control? Was it different feel after you fitted your new tyres ? Found mine is slightly different ! Hopefully running tyres on lower psi will sort it out.. Mine are Falkens, no problem with steering. maybe you need the geometry checked Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted November 20, 2013 Share Posted November 20, 2013 I run mine at 30 to 32 psi instead of 35 psi, makes a vast difference to the ride. I do the same with my Falkens Mine are Falkens. Quote Link to comment Share on other sites More sharing options...
Dashurik Posted November 20, 2013 Author Share Posted November 20, 2013 (edited) I run mine at 30 to 32 psi instead of 35 psi, makes a vast difference to the ride. Thanks for advise,I ll do so ,see if that will change the ride! How is your steering wheel control? Was it different feel after you fitted your new tyres ? Found mine is slightly different ! Hopefully running tyres on lower psi will sort it out.. Mine are Falkens, no problem with steering. maybe you need the geometry checked May be! Did it two month ago when was changing few bits on the car,but back then I was running on old tyres.Just wondering ,lowering psi on tyres won't it put more wear on them? Edited November 20, 2013 by Dashurik Quote Link to comment Share on other sites More sharing options...
AMT Posted December 5, 2013 Share Posted December 5, 2013 453's all round, always had good grip from em', only if its greasy do you need to watch it doesn't slip out, front or rear. Generally they'll do you good! Generally run mine around 35 and never had any issues. Quote Link to comment Share on other sites More sharing options...
SamN Posted December 5, 2013 Share Posted December 5, 2013 I heard a lot of bad reviews about the 453 as opposed to the 452. I've had quite a few 452s and found them great. You're right in thinking the 453s are harder but as above try letting a little air out. Quote Link to comment Share on other sites More sharing options...
tony.r123 Posted December 5, 2013 Share Posted December 5, 2013 I run 453's and find them to be excellent Quote Link to comment Share on other sites More sharing options...
cs2000 Posted December 5, 2013 Share Posted December 5, 2013 I run 453's and find them to be excellent Me too, actually run them at 36PSI. The zed just gives a hard ride all the time to be honest, noticed no ride quality change from the REO40's on before. Quote Link to comment Share on other sites More sharing options...
SamN Posted December 5, 2013 Share Posted December 5, 2013 Fair enough, I can't comment as I haven't tried them! Quote Link to comment Share on other sites More sharing options...
