Nick350z Posted January 10, 2014 Author Share Posted January 10, 2014 I don't know. All the other discs/pads were fine and they had no issues with fitting them. To be honest I've used the garage several times in the past and always come away happy with the work they have done so I had no reason think they had done anything beyond what they needed to do. The chap did say to me that if I experience any problems that I should bring it back and they'll be happy to take a look. Without further investigation it's difficult I know what the problem is. Could be something they've done, could be a manufucturing fault, could be something caught between the pad and disc. I'll take it in on Monday and see what they say. Quote Link to comment Share on other sites More sharing options...
Nick350z Posted January 13, 2014 Author Share Posted January 13, 2014 Well I've had it looked at. They couldn't find any faults so I can only draw the conclusion that something had gotten caught between the pad and disc and scored the disc. Fortunately it's not deep, and doesn't appear to be getting any worse, so will fade as the disc wears through. Anyway - the brakes look and feel good and I recommend them :-) Quote Link to comment Share on other sites More sharing options...
Daryl Posted January 13, 2014 Share Posted January 13, 2014 After a track day last year, by back discs developed a ring around them, sounds like the same as what you have. When i took the pads out, I noticed that there was some debris of some sorts, either pad or something, in the gap on the pad, This was causing the pad to hold off or something. Once id removed the debris, it was fine. Quote Link to comment Share on other sites More sharing options...
Daryl Posted January 13, 2014 Share Posted January 13, 2014 This is what I had Quote Link to comment Share on other sites More sharing options...
Nick350z Posted January 13, 2014 Author Share Posted January 13, 2014 Thanks for posting that up - exactly what mine looks like - just slightly more towards the centre. Quote Link to comment Share on other sites More sharing options...
Daryl Posted January 15, 2014 Share Posted January 15, 2014 Remove the pads and give them a clean. You may also find the inside of the disc is the same. Dont use a solvent or anything, just clean the gap out with a screw driver or something. Quote Link to comment Share on other sites More sharing options...
Tommy Kaira Posted February 12, 2014 Share Posted February 12, 2014 Any info on these?? These are sexy: Quote Link to comment Share on other sites More sharing options...
HaydnH Posted February 12, 2014 Share Posted February 12, 2014 Any info on these?? These are sexy: Here buddy: http://www.350z-uk.com/topic/69782-art-6-piston-357mm-kit-for-350z-370z-front-1550-rear-330mm-1500/ Quote Link to comment Share on other sites More sharing options...
