Headlight adjustment
PS13Silvia
  • 4 weeks later...
  • 2 months later...
Not with hids unfortunately if they are factory options. They have sensors to check what angle the front of the car is pointing and they adjust automatically. Eg if you have a lot if stuff in he boot and it pushes the nose up the lights will angle down so they don't glare anyone
Did you notice this after fitting the springs ? Did it lower more at the rear ?
Yes noticed more so after lowering (Eibach) the front is 5mm lower than rear though. Might just be the fact the car is lower so light angle hasn't changed but doesn't reach as far.
The extra 5mm does annoy me, a set of Ohlins R&T are on the cards now though :)
