evilscorp Posted September 22, 2016 Share Posted September 22, 2016 Turbo speed sensor? Or is that a pain to fit? (clueless about them). Other wise engine oil pressure should be fine. 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted September 22, 2016 Author Share Posted September 22, 2016 Turbo speed sensor? Or is that a pain to fit? (clueless about them). Other wise engine oil pressure should be fine. speed sensor would be cool to have but wont really tell me how much oil I need to scavenge I think oil feed pressure based control is going to be the best bet Quote Link to comment Share on other sites More sharing options...
andybp Posted September 28, 2016 Author Share Posted September 28, 2016 So all of the oil pipework is now fitted I've decided to try to control the scavenge pump based on the engine oil pressure obviously when the oil is cold the pump will be running faster than necessary but nothings perfect (well except me ) I've made a new scavenge pump controller basically a Darlington driver driven from a PWM signal from an Arduino NANO which will be looking at the engine oil pressure and controlling pump speed based on my dodgy maths to keep the wiring simple the driver is going to be next to the pump so this is now sealed in potting compound which when it's cured should protect it from the elements yea I know it looks like a mess right now but it'll look fine when it's done hopefully when i get home tomorrow Quote Link to comment Share on other sites More sharing options...
evilscorp Posted September 28, 2016 Share Posted September 28, 2016 You ain't going to miss where you spill that stuff! 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted September 30, 2016 Author Share Posted September 30, 2016 95% finished just need to set the Wastegates and adjust the scavenge pump controller as it's running too slow on idle except when cold and it runs at 100% due to the viscosity so I may add a temperature sensor to offset this, also the valve in the silencer is not connected electrically yet it's just wide open will get a couple of hours to play tomorrow morning while the missus has her piano lesson then I need to finish the conservatory roof before I play anymore or the missus will beat me 1 Quote Link to comment Share on other sites More sharing options...
Speedy1984 Posted October 5, 2016 Share Posted October 5, 2016 Awesome thread bud 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted October 6, 2016 Author Share Posted October 6, 2016 Awesome thread bud You only joined yesterday did you read it all ? That would take a while Quote Link to comment Share on other sites More sharing options...
Speedy1984 Posted October 6, 2016 Share Posted October 6, 2016 Awesome thread bud You only joined yesterday did you read it all ? That would take a while I looked at all the important bits/looked through all the pics lol.No it's some great Diy skills bud.Have you redirected the exhaust gas flow to the turbo first fan in some way. 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted October 6, 2016 Author Share Posted October 6, 2016 Had a few annoying problems with the latest version of my rear mount setup the BOV wasn't opening causing compressor surge sounded cool the first couple of times but became embarrassing and annoying very quickly there were metal filings between the piston and the bore of the BOV my own fault must have been while it was sitting in my garage during the rebuild I should of covered it it was too loud anyway Luckily I had one laying around I believe off a skyline So I made an adapter up from some ally plate And we're back in business The new compressor I went for on this turbo is excellent feels less restrictive at lower revs and makes more boost than I know what to do with 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted October 6, 2016 Author Share Posted October 6, 2016 Awesome thread bud You only joined yesterday did you read it all ? That would take a while I looked at all the important bits/looked through all the pics lol.No it's some great Diy skills bud.Have you redirected the exhaust gas flow to the turbo first fan in some way. I made a quick spool setup on the first version using a wastegate to control the gas flow but the turbo sizing was way off on the third turbo now it's like Goldilocks and the three bears but Andy and the three turbo'sthe first one was too big, the second one was too small the third one was just right 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted October 7, 2016 Author Share Posted October 7, 2016 I was still having a few issues with the BOV looks like the small vacuum hose connecting it to the intake was collapsing under vacuum have now changed it for a thicker walled pipe all okay now, still a few rattles from some of the new pipework also need to sort out a usable all weather air filter setup as I wouldn't want to drive through any deep puddles so will have a play tomorrow. Quote Link to comment Share on other sites More sharing options...
andybp Posted December 18, 2016 Author Share Posted December 18, 2016 So the setups been up and running for a couple of months now had a few issues with the scavenge pump not keeping up at high engine revs after fitting a 2mm restrictor in the oil feed and a small ally sump on the turbo drain that was all sorted it made 5psi from 2500 rpm up to the redline Achieved everything I set out to do but now I'm bored I did it , it works it wasn't about the power I can't use it around here anyway I just like a challenge. So it's all coming back off and going back to an N/A setup (maybe DIY individual throttle bodys ) some people may think i'm mad but why pay the extra insurance on something i'm not using I've had great fun doing it but it's time to put this project to bed Thanks to everyone for their interest in this project and putting up with my ramblings 1 1 Quote Link to comment Share on other sites More sharing options...
Floydbax Posted December 18, 2016 Share Posted December 18, 2016 Thanks for keeping me amused lol 1 Quote Link to comment Share on other sites More sharing options...
350jimbobz Posted December 18, 2016 Share Posted December 18, 2016 Wasn't expecting that post. Any videos? You selling the set up ? Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted December 18, 2016 Share Posted December 18, 2016 Totally understandable Andy, ....nah I'm kidding, you're bonkers really. Seriously though I do kind of understand where you're coming from as I do get a lot of satisfaction from making things myself often with the end product/kit/part etc not being as fun as the fun I had along the way making it. 1 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted December 18, 2016 Share Posted December 18, 2016 Been fascinating to follow, looking forward to the next one! 1 Quote Link to comment Share on other sites More sharing options...
j0bj0sh Posted January 10, 2017 Share Posted January 10, 2017 just spent the last 4 hours reading these 24 pages.. to find no dyno run or finished photos! its like waving sweets infront of a child and eating it yourself. amazing work and great fab skills and know how! love the commitment even when your car takes you for a walk!! Quote Link to comment Share on other sites More sharing options...
andybp Posted January 10, 2017 Author Share Posted January 10, 2017 just spent the last 4 hours reading these 24 pages.. to find no dyno run or finished photos! its like waving sweets in front of a child and eating it yourself. amazing work and great fab skills and know how! love the commitment even when your car takes you for a walk!! This is pretty much the finished setup minus the small ally sump for the turbo drain I would have taken a few final photos for you but it's all removed now just a turbo an intercooler and a big pile of pipework in the corner of my garage not sure what I'm going to do with it all yet it has to go it's in the way. so the Z now has a dual hks type exhaust,high flow cats,phenolic inlet spacer and the fuel return system and I'm still using the utec ecu so pretty stock for me until I start the individual throttle body setup when the weather improves. Quote Link to comment Share on other sites More sharing options...
lmc Posted January 10, 2017 Share Posted January 10, 2017 just spent the last 4 hours reading these 24 pages.. to find no dyno run or finished photos! its like waving sweets in front of a child and eating it yourself. amazing work and great fab skills and know how! love the commitment even when your car takes you for a walk!! This is pretty much the finished setup minus the small ally sump for the turbo drain I would have taken a few final photos for you but it's all removed now just a turbo an intercooler and a big pile of pipework in the corner of my garage not sure what I'm going to do with it all yet it has to go it's in the way. so the Z now has a dual hks type exhaust,high flow cats,phenolic inlet spacer and the fuel return system and I'm still using the utec ecu so pretty stock for me until I start the individual throttle body setup when the weather improves. Work a price out and let me know pretty please lol. Quote Link to comment Share on other sites More sharing options...
j0bj0sh Posted January 11, 2017 Share Posted January 11, 2017 such impressive work! loved all the electronic magic!! looks great too. shame your not a fan! im sure someone will snap it up for £5k half price turbo kit right there Quote Link to comment Share on other sites More sharing options...
andybp Posted January 11, 2017 Author Share Posted January 11, 2017 (edited) such impressive work! loved all the electronic magic!! looks great too. shame your not a fan! im sure someone will snap it up for £5k half price turbo kit right there if i sell it will be as a load of pipework+ miscellaneous bits a turbo and an intercooler maybe even an ecu as i have a spare not as a ready to go turbo kit some of the welding especially the ally is crap but if i do it will be to someone with sufficient skills to install and fabricate the mounts for the intercooler etc and if i do it will be a few hundred not thousand to a good home. Edited January 11, 2017 by andybp 2 Quote Link to comment Share on other sites More sharing options...
Diggerman Posted October 15, 2018 Share Posted October 15, 2018 I'd be more than interested in buying it off you if you do sell, I was about to book mine into a local garage for a rear mount after I watched countless videos on YouTube of the std kit which just sounds evil Quote Link to comment Share on other sites More sharing options...
andybp Posted October 15, 2018 Author Share Posted October 15, 2018 9 hours ago, Diggerman said: I'd be more than interested in buying it off you if you do sell, I was about to book mine into a local garage for a rear mount after I watched countless videos on YouTube of the std kit which just sounds evil All gone sorry, another member on here is playing with it Quote Link to comment Share on other sites More sharing options...
Diggerman Posted October 15, 2018 Share Posted October 15, 2018 Dam I thought it would be a slim chance of you still having it one question I do have though is the oil scavenge side of things, would I be right in thinking that a feed from a sandwich plate and then a 1mm restrictor into the turbo would be enough and then run the scavenge pump straight to sump? Possibly via a small sump Quote Link to comment Share on other sites More sharing options...
andybp Posted October 15, 2018 Author Share Posted October 15, 2018 7 minutes ago, Diggerman said: Dam I thought it would be a slim chance of you still having it one question I do have though is the oil scavenge side of things, would I be right in thinking that a feed from a sandwich plate and then a 1mm restrictor into the turbo would be enough and then run the scavenge pump straight to sump? Possibly via a small sump yes but bear in mind the scavenge pumps are the weak point in these setups and have a tendency to fail the final setup I did before I removed mine controlled the pump speed based on the oil pressure feeding the turbo most people just run them full speed Quote Link to comment Share on other sites More sharing options...
