andybp Posted July 11, 2016 Author Share Posted July 11, 2016 Ok don't laugh but once I've finished the fuel system I'm starting again even though this project has never really finished. I'm just not happy with the layout of the pipework and lack of clearances causing rattles i just can't seem to get rid off and just how overly complex it got from bitter experience this leads to unreliability so I've ordered another turbo which should arrive this week and a few other little items the turbo is the same as i have now I just didn't want to have my car in bits too long so having another turbo will let me do a lot of the fabrication off the car just for convenience really this shows the exhaust I used for this project and because I wanted to be able to return the car to standard easily and just fit the backbox in place of the turbo I chose not to modify the system even though this restricted the layout This time around I'm going to weld a new pipe to the center section as shown but just fit a blanking plate to the original flange on the end of the pipe this way I can still fit the standard backbox by blanking the new pipe if required this is the setup I plan to go with the pipe across from the main exhaust from the turbo is for show not flow the backbox I have at present will go to be replaced by a pair of small silencers just before the tailpipes probably a slightly larger one in the passenger side pipe as this will flow most of the exhaust gas also and this will be the controversial I told you so part I will probably lose the stand alone oil system not because it doesn't work oil pressure is 100% stable with no load on the engine oil/cooling system which was the idea but because with a scavenge pump and feed pump running when the oil is hot it's just a bloody irritating whine I will still have an oil cooler prior to the scavenge pump to aid pump reliability and reduce any load on the engines cooling system from the turbo also I will be replacing the charge pipework from the turbo to the intake which is currently made from thin wall stainless steel with aluminium Bear in mind that my Z (Christine) is a toy and i'm doing this for fun 2 Quote Link to comment Share on other sites More sharing options...
Keyser Posted July 11, 2016 Share Posted July 11, 2016 I shall follow the venture into the mk 2 with interest Quote Link to comment Share on other sites More sharing options...
andybp Posted July 14, 2016 Author Share Posted July 14, 2016 Ok well the fuel return system is all installed and running now. The only problem I had was the O-Ring between the fuel bucket and the tank maybe I should apologise to my neighbours for throwing my teddy down and shouting F***ing S***ing F***ing S**t F**k as they walked past with their kids but I got it in ok in the end also this arrived today ready for the mk2 as mr K is calling it although I'm sure we're at mk3 or 4 already in the previous post I said I'd ordered the same turbo as before well almost at the last minute I changed the compressor trim from 48 to 56 as I felt it was restricting airflow we'll see if it causes a problem I'll change it also in the previous post I didn't mention that I'm going to use the internal wastegate on the turbo this time around if it doesn't bypass enough gas to keep the boost down I'll install another wastegate at the end of the blanked off pipe that would have gone to the backbox 3 Quote Link to comment Share on other sites More sharing options...
Stemo Posted August 8, 2016 Share Posted August 8, 2016 Looks nice! Are you using original UTEC map sensor or did you buy 3bar GM sensor? I have brand new STS kit waiting on the shelf, I'm bit hesitating if I should install it or sell it (I got it for bargain from US so I bought it anyway) but looking your thread sure makes me want to go rear mount way myself! 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted August 8, 2016 Author Share Posted August 8, 2016 Looks nice! Are you using original UTEC map sensor or did you buy 3bar GM sensor? I have brand new STS kit waiting on the shelf, I'm bit hesitating if I should install it or sell it (I got it for bargain from US so I bought it anyway) but looking your thread sure makes me want to go rear mount way myself! can't see there's any value in going to the GM 3 Bar sensor i'm not sure what the standard UTEC one is rated to but it's more than enough on a 350 rear mount or is there something i'm missing (it wouldn't be the first time) Quote Link to comment Share on other sites More sharing options...
Stemo Posted August 10, 2016 Share Posted August 10, 2016 You are not missing anything, I was just wondering because all of the UTEC-s I have seen on Ebay are without the MAP sensor. Quote Link to comment Share on other sites More sharing options...
andybp Posted August 10, 2016 Author Share Posted August 10, 2016 You are not missing anything, I was just wondering because all of the UTEC-s I have seen on Ebay are without the MAP sensor. you can pretty much use any 3 wire sensor on the UTEC as long as you have an accurate pressure source to calibrate it from Quote Link to comment Share on other sites More sharing options...
andybp Posted August 11, 2016 Author Share Posted August 11, 2016 Had a couple of hours this afternoon so decided there's no time like the present to start on the Mk 4 ,5, 6 or whatever version of this build I'm up to anyway it's more of an evolution than a different version I was going to do a before and after picture but the missus was menacing me so had to stop playing but you get the idea from the before And the pile of bits a couple of hours later I've put the old Backbox on and it's all drivable all ready to start again Quote Link to comment Share on other sites More sharing options...
Stutopia Posted August 11, 2016 Share Posted August 11, 2016 I'd be distraught after all that work, you seem to be excited! 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted August 11, 2016 Author Share Posted August 11, 2016 I'd be distraught after all that work, you seem to be excited! Yea I am excited I could do this all day every day in fact I've got a silly grin on my face Just thinking about it Quote Link to comment Share on other sites More sharing options...
andybp Posted August 15, 2016 Author Share Posted August 15, 2016 so I've got a bit done this afternoon got the new takeoff welded on to the mid pipe much better location for the turbo than the previous setups i have tried so far my new ramps are making it much easier as i can actually sit underneath the back of the car this is the exhaust mid section off the car so i can finish the welding hope to get this welding finished after work tomorrow so i can use the car again will just make a blanking plate for the flange where the turbo mounts and bolt the back box back on 1 Quote Link to comment Share on other sites More sharing options...
jumping350 Posted August 15, 2016 Share Posted August 15, 2016 looking great pal awesome fabrication skills as always 1 Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 15, 2016 Share Posted August 15, 2016 Nice welds mate put mine to shame Keep up the good work 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted August 15, 2016 Author Share Posted August 15, 2016 Nice welds mate put mine to shame Keep up the good work Glad you think it's good my dad popped by earlier and said it looked like bird S**t but he was a coded welder Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 15, 2016 Share Posted August 15, 2016 Love those ramps 1 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted August 15, 2016 Share Posted August 15, 2016 Silly question alert. With your continuous adding, removing, fettling (very interesting it is too) how do you have a "safe" map for just using it in all these various states? 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted August 16, 2016 Author Share Posted August 16, 2016 Love those ramps Me too the price tag wasn't so nice though but the ramps are really good Quote Link to comment Share on other sites More sharing options...
andybp Posted August 16, 2016 Author Share Posted August 16, 2016 Silly question alert. With your continuous adding, removing, fettling (very interesting it is too) how do you have a "safe" map for just using it in all these various states? I have a few different maps which I tweak on the road using my wideband afr not ideal but not worth getting it tuned until i stop playing 1 Quote Link to comment Share on other sites More sharing options...
andybp Posted August 16, 2016 Author Share Posted August 16, 2016 minor update got the welding all finished on the mid pipe and made a blanking plate up for the turbo flange have fitted the backbox and the Z is back on the road so I will be able to use it if needed just need my new silencers to show up refill my gas bottle and I can get on. Quote Link to comment Share on other sites More sharing options...
andybp Posted August 21, 2016 Author Share Posted August 21, 2016 Not much of an update just trying to update as I go Had another change of plan as the Backbox I was going to use was pretty much destroyed by the courier company looked like they played football with it the delivery guy kept apoligising it was so bad so rejected delivery and cancelled order and decided to reuse the old one instead got most of the welding done on it today (no pictures sorry) just got to cut off the old and weld on the new tailpipes and weld on the valve that feeds one of the tailpipes so i can reduce the noise level to save irritating my neighbors just waiting for my new tailpipes (which will probably arrive damaged) and need to refill my gas bottle as it's absolutely empty Quote Link to comment Share on other sites More sharing options...
andybp Posted August 25, 2016 Author Share Posted August 25, 2016 well my comment in the above post about my new tailpipes arriving damaged was a major understatement mangled to F*&% would have been closer so they went back and i decided to make my own I think they would have been a bit small anyway so this is what i came up with, what do you think I think I will have modify the rear valance to make it look right but I think the four 2 1/2" pipes looks pretty cool the inside 2 are 3mm longer so it follows the line of the valance better This is the valve which will shut off the straight through section of the silencer to quieten down the exhaust to save annoying my neighbors I won't get any more done now until Sunday the new aluminium charge pipework arrived today (The previous version used thin wall stainless) other than some silicone hose I just need some time. 4 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted August 25, 2016 Share Posted August 25, 2016 Like the quads. Unusual. Quote Link to comment Share on other sites More sharing options...
scobie140 Posted August 26, 2016 Share Posted August 26, 2016 Big fan of the quads, keep meaning to take mine back to get quads swapped on Quote Link to comment Share on other sites More sharing options...
GMballistic Posted August 26, 2016 Share Posted August 26, 2016 Great work Andy. Dedication. Quote Link to comment Share on other sites More sharing options...
andybp Posted August 26, 2016 Author Share Posted August 26, 2016 Like the quads. Unusual. Exactly why I'm going with it the rarity factor 1 Quote Link to comment Share on other sites More sharing options...
