RDON Posted November 10, 2013 Share Posted November 10, 2013 (edited) hi folks. I have noticed an intermitted fault all of a sudden with my drivers side window, it doesn't drop sometimes when I open the door so when I come to close it the glass is smacking the A panel roof section. im worried it will break the glass, can this be fixed? has anyone else had this? it is like the window is not dropping enough maybe when the door is open, but then sometimes it works ok? your experience or advice is great appreciated? Edited November 10, 2013 by rickdon Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 10, 2013 Share Posted November 10, 2013 A reset which you will find in the guides section should fix this issue. Alex. Quote Link to comment Share on other sites More sharing options...
KyleR Posted November 10, 2013 Share Posted November 10, 2013 (edited) Does it work when you use the button to lower it? If not you'll need to give the motor a reconditioning or buy a new one. Edited November 10, 2013 by KyleR Quote Link to comment Share on other sites More sharing options...
RDON Posted November 11, 2013 Author Share Posted November 11, 2013 the window motor works fine, goes up and down fine! Alex I will see if I can find the reset thread, thanks. Quote Link to comment Share on other sites More sharing options...
Ricey Posted November 11, 2013 Share Posted November 11, 2013 Do the reset and it'll be fine. They just lose their memory sometimes. Quote Link to comment Share on other sites More sharing options...
RDON Posted November 19, 2013 Author Share Posted November 19, 2013 after you open the door and wait 10 -20 seconds, I hear a click sound coming from behind the drivers seat then the window will drop a bit! is there some kind of relay back there? Quote Link to comment Share on other sites More sharing options...
MarkZZZ Posted January 29, 2021 Share Posted January 29, 2021 I have the same clicking noise from behind the seat. Or did. No it doesn't auto drop at all. I'll look for the reset guide. It was fine in summer? Quote Link to comment Share on other sites More sharing options...
Ebized Posted January 29, 2021 Share Posted January 29, 2021 On 10/11/2013 at 16:32, ZMANALEX said: A reset which you will find in the guides section should fix this issue. Alex. Quote Link to comment Share on other sites More sharing options...
