Help Fitting LED Rear Lights,
WhackyWill
I have bought a set of Genuine Nissan LEDs
from a member on here, they were fitted to an
JDM import and I want to fit them to my UK 06
pre facelift, the plugs are different and don't fit
Into each other, somebody said you need to
shave them, cannot see where you do this.
I remember you had to shave the connector to fit the UK lights onto a JDM.
I suppose you would have to unshave them or see if you can get replacement connectors
This is the other way around, they came from a JDM doesn't look like any connectors have been shaved.
and I'm fitting them on my UK spec spec DE. :wacko:
Edited by WhackyWill
What he said ^^^
On the bottom picture, you can see 3 spaces for guides, two at the top and one double one at the bottom, it's these guides on the loom that need shaved off. I made the mistake earlier saying it was guides on the light that need shaved I think.
You could spend X amount of money on new ones, plus however long it takes to remove the wires from the original connectors. OR, you could spend 10 minutes filing them down.
Did you find the connector on down from the bulb fitting?
So there is a bit down from the bulb fitting ?? No. :surrender:
