350 Russ Posted November 1, 2013 Share Posted November 1, 2013 I changed my Clutch slave cylinder last week but the nut from the solid pipe to the hose wouldn't budge and ended up rounding off. So this go me thinking, how hard would it be to change the ridged pipe from the master cylinder to the slave cylinder? Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 1, 2013 Share Posted November 1, 2013 A PITA as it winds it's way through the car - however if you take off the passenger side front wheel arch liner (rear part) you will find a big valve the hard pipe from the slave cylinder runs to the bottom and is a fairly easy change. The top pipe from the valve is one piece that runs back to the master cylinder IIRC it runs along under the windscreen wipers in front of the bulkhead. Hope it helps Quote Link to comment Share on other sites More sharing options...
350 Russ Posted November 1, 2013 Author Share Posted November 1, 2013 perfect! thats a right result then. Ive just dug out my old workshop manual cd and found what you mean, couldn't have been much better really Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 2, 2013 Share Posted November 2, 2013 As what Chris has said or you can simply cut off the flare and remove the damaged nut, fit new nut and then make new flare. The repaired pipe will be circa 5mm shorter, however it will reach the hose. The tools required would be a small hacksaw, file and a flaring tool. Alex. Quote Link to comment Share on other sites More sharing options...
350 Russ Posted November 2, 2013 Author Share Posted November 2, 2013 thats a good shout, but the braided clutch hose that i have has a female end to it, is there a nipple type fitting in-between the pipe and hose? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 2, 2013 Share Posted November 2, 2013 The flare makes the seal mate. Just carry out as above and fit a new male nut to replace your damaged one. Alex. Quote Link to comment Share on other sites More sharing options...
