JohnUKVetteNut Posted October 31, 2013 Share Posted October 31, 2013 Hi Folks I am now thinking of anti rusting the underneath of my import JDM...was never done when brought in, and showing some rust signs. As winter is approaching it would be the ideal time. My question is to "what ramp width" do I need allow wide wheels to run up ok? My tyres are 245 wide but the only ramps i can see are up to 200 wide? Anyone help me choose please? I already have the ramp extenders ( early xmas pressie!) for low front end to run up ok. Cheers JohnUKVetteNut Quote Link to comment Share on other sites More sharing options...
GMballistic Posted October 31, 2013 Share Posted October 31, 2013 Can't you just use four axle stands and a trolley jack to lift it up instead? http://www.sgs-engineering.com/hydraulic-jacks/trolley-jacks http://www.sgs-engineering.com/hydraulic-jacks/axle-stands Quote Link to comment Share on other sites More sharing options...
JohnUKVetteNut Posted October 31, 2013 Author Share Posted October 31, 2013 Yes. I could do that but I have not got a low height trolley jack, and as I had an unhappy experience with a car on axlestands( my previous car was a Corvette) and I managed to get 2 front axlestands under it then attempted to jack up the rear on the diff ( bad idea as I found out)and it nearly got where i could slip the axlestands under and it slipped sideways.....caught my foot and then both the front axlestands twisted and the car just slid off and trapped the axlestands under itself. All I got was a bruised shin and very damaged ego!! Luckily car was ok, so thats why I was trying to go the ramps way!! Long story but that explains my preference for ramps. JohnUKVetteNut Quote Link to comment Share on other sites More sharing options...
GMballistic Posted November 1, 2013 Share Posted November 1, 2013 ^^ Think I'd want ramps too after that. Could have been so much worse though by the sounds of it. Glad you weren't hurt worse & the car was fine. What about these; http://www.amazon.co.uk/Car-Ramps-ton-Clearance-Wide/dp/B005BPHDQI Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 1, 2013 Share Posted November 1, 2013 That shouldnt of happened though. Quote Link to comment Share on other sites More sharing options...
Lexx Posted November 1, 2013 Share Posted November 1, 2013 You can get flat style ramps which means regardless of their width you'll be able to drive up onto the fine without deformin your tyres. Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted November 1, 2013 Share Posted November 1, 2013 Just had my whole car undersealed, cost 90 with my garage over night. Looks lovely and all the rust treated before hand. It's only surface. But worth doing. Quote Link to comment Share on other sites More sharing options...
JohnUKVetteNut Posted November 2, 2013 Author Share Posted November 2, 2013 Yes DBlock you are righ,t but I had the jack on the diff housing to lift both rear wheels at the same time and it slipped sideways off the circular diff housing as I was attempting to put the first axle stand under the rear end, then the front stands twisted and all just went wrong after that. I guess that the front axle stands I had were a very narrow "footprint" base. I then replaced them with wide base stands but now reluctant to stands at all!!! The large plastic ones( thanks GMballistic) look very stable but I am trying to find out their dimensions! Again thanks for responses guys. JohnUKVetteNut Quote Link to comment Share on other sites More sharing options...
GMballistic Posted November 2, 2013 Share Posted November 2, 2013 Yes DBlock you are righ,t but I had the jack on the diff housing to lift both rear wheels at the same time and it slipped sideways off the circular diff housing as I was attempting to put the first axle stand under the rear end, then the front stands twisted and all just went wrong after that. I guess that the front axle stands I had were a very narrow "footprint" base. I then replaced them with wide base stands but now reluctant to stands at all!!! The large plastic ones( thanks GMballistic) look very stable but I am trying to find out their dimensions! Again thanks for responses guys. JohnUKVetteNut If you scroll down the page on that Amazon advert it states; Technical Details Car Ramps Black Length 90cm Height: 17cm Width: 30cm Quote Link to comment Share on other sites More sharing options...
