Y23DRH Posted October 29, 2013 Share Posted October 29, 2013 350z roadster i have a seriously bad vibration from the gearbox area whole car vibrates but only when you let off the throttle it's dam annoying and very loud any one heard of this before looked to see if its the exhaust but don't touch the body any where the vibration is comeing from the gearbox area any ideas would be very greatfull Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 29, 2013 Share Posted October 29, 2013 Have you checked out the gearbox mounts? They could be shot. Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 29, 2013 Share Posted October 29, 2013 Have you also checked the fluid level and when it was last changed? Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted October 29, 2013 Share Posted October 29, 2013 (edited) Check the gearbox supports to see if a bolt has worked loose or sheared! Edited October 29, 2013 by 4RE Leather Quote Link to comment Share on other sites More sharing options...
Y23DRH Posted October 29, 2013 Author Share Posted October 29, 2013 Have you checked out the gearbox mounts? They could be shot. Gear box mounts seem to be ok Fluid all toped up at last service just over 3 weeks ago Had a look at the supports they seem to be very tight only found one lose one had a long bolt and bit or rubber attached to it tightend back up but nosie still there :/ Will see if i can get the car in the garage this week and have it checked over sounds dreadfull goes away once the cars warm then back again when cold ? Quote Link to comment Share on other sites More sharing options...
Y23DRH Posted October 29, 2013 Author Share Posted October 29, 2013 Been told could be clutch or flyhweel problem :/ Quote Link to comment Share on other sites More sharing options...
