How to remove and change the gear gaiter?
Zed_lover
It's easy you just pull it off place your hand at the back off the ring and pull it to the back off the car don't pull it to much become there are two bus bar wires plugged in to it. Then unscrew the gear nob and remove then all you need to do is remove some small screws will find the link for you on YouTube
