Zhorno Posted October 26, 2013 Share Posted October 26, 2013 Want to take mine off to spray , are they stuck on or do they have clips don't want to start pulling if I'm gunna break it lol Quote Link to comment Share on other sites More sharing options...
JordanHill Posted October 26, 2013 Share Posted October 26, 2013 I believe theyre stuck on? Quote Link to comment Share on other sites More sharing options...
Ebized Posted October 26, 2013 Share Posted October 26, 2013 Did you not look in the FAQ/Guides section then http://www.350z-uk.com/topic/63099-z-badge-installation/ Quote Link to comment Share on other sites More sharing options...
Easty Posted October 28, 2013 Share Posted October 28, 2013 There just stick on, I did mine a few weeks ago Just heat up and pull off Quote Link to comment Share on other sites More sharing options...
Zhorno Posted October 28, 2013 Author Share Posted October 28, 2013 U just stick them back in with double sided tape Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 29, 2013 Share Posted October 29, 2013 I removed mine from the boot and it was just stuck on and really easy to remove although I have seen some on you tube that have 2 drilled holes in which to take small pegs al though I believe these are for the USA market only. Not sure about the bonnet badges though. Quote Link to comment Share on other sites More sharing options...
zippypooz Posted October 30, 2013 Share Posted October 30, 2013 Make sure you heat it up with a heat gun, should come off fine, if not, use dental floss, put the floss behind the badge and with a left and right motion gradually work your way through the adhesive!! 1 Quote Link to comment Share on other sites More sharing options...
mattfinch Posted November 9, 2013 Share Posted November 9, 2013 Best thing to do is spray with plasti dip that way you don't need to take them off to spray them and you can just peel off the spray you don't want Quote Link to comment Share on other sites More sharing options...
zippypooz Posted November 9, 2013 Share Posted November 9, 2013 Best thing to do is spray with plasti dip that way you don't need to take them off to spray them and you can just peel off the spray you don't want Whats the minimum amount of plasti dip you can get? Have you used it? Quote Link to comment Share on other sites More sharing options...
mattfinch Posted November 9, 2013 Share Posted November 9, 2013 Not sure on the smallest size but I used a 400ml can i had about a quarter left after doing 3 coats on my front and back badges and the 350z back badge and my front bumper lip. Its very easy to use and the excess spray that goes on the bodywork just peals right off. Loads of vids on youtube about doing the 350z badges Quote Link to comment Share on other sites More sharing options...
billybobtrucking Posted November 9, 2013 Share Posted November 9, 2013 I got mine of by tipping hot(not boiling ) water out of kettle and then carefully lifting the edge with a flat screwdriver blade with a bit of cloth under it .Any glue left i polished off . Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted November 9, 2013 Share Posted November 9, 2013 The badges look nice as they are I think. Quote Link to comment Share on other sites More sharing options...
RafsZed Posted November 9, 2013 Share Posted November 9, 2013 eBay sell the front and rear badges with just a Z in the middle and it not saying Nissan, looks good, very tempting. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted November 9, 2013 Share Posted November 9, 2013 The badges look nice as they are I think. Totally agree with you but it seems once some people get Zeditus nothing is safe. 1 Quote Link to comment Share on other sites More sharing options...
