Exhaust Gaskets
rog518
Hi,
Does anyone know what exhaust gaskets should go in each section of the OEM exhaust?
I am replacing the center section tomorrow and it has been sent with a 2 bolt 63mm metalic flat gasket and metal sealing ring.
It looks like the flat gasket goes between the center flange and y pipe and sealing ring goes from center to back box. The reason I am questioning this is that when I had the back box fitted they used a flat gasket and not the sealing ring and or both can't remember but can see flat gasket.
Just want to make sure as have the car booked into garage tomorrow afternoon and if I'm short of a flat gasket im stuck.
Many thanks
Roger
