Exhaust and catalysers
David1951
I'm sure this topic comes up frequently! The original exhaust in my 350 has after 65k started to fail. What parts will I require for my local small garage to replace the system? I guess I will need new cats? Will the old cats be worth. Anything?
Thanks. David
As above, have a look at what is broken and replace what is necessary. I can't imagine the cats have failed. If the flexis have broken then a new Y-pipe will be sufficient and if the mid pipe to back box connection is broken then a weld repair or a y-pipe back system will do.
