Grundy Posted October 17, 2013 Share Posted October 17, 2013 Hi guys, Had the zed for about 5 days now, everything is fine and I'm loving it! However got in the car this morning and the Air Bag Light randomly started blinking at me. Nothing changed, not touched under the seats etc, done the same I've been doing for the past 5 days of owning it. Did a quick google search and was given tricks on how to reset and clear the light:- -Turn ignition on -Wait 7 seconds for the light to turn off -Turn car off within 1 seconds of the light switching off -Repeat the above 3 times. Now the first time I did that it slowed the blinking down, before it was On Off on a 1 second ratio, it was now 2-3 second ratio. Then when I stopped my journey and did the same again, this time it stayed off for a few minutes then came back on and this time was back to the original 1 Second Ratio. Hope that makes sense, did a quick forum search of 'Air Bag Light' but couldn't find anything so apologies if there is a thread on this already. Cheers Matt 1 Quote Link to comment Share on other sites More sharing options...
Grundy Posted October 17, 2013 Author Share Posted October 17, 2013 Ignore this, sorry found a few threads on the forum after further searching, will read through them 1st. Quote Link to comment Share on other sites More sharing options...
buster Posted October 17, 2013 Share Posted October 17, 2013 when you get chance ,un plug all connections under the seats and clean.re connect and reset .hopefully this should work. Quote Link to comment Share on other sites More sharing options...
Grundy Posted October 17, 2013 Author Share Posted October 17, 2013 Are they easy to get to? Because in the golf they were a pain the butt! Quote Link to comment Share on other sites More sharing options...
buster Posted October 17, 2013 Share Posted October 17, 2013 (edited) yeah not that bad m8.you could always remove the seats only 4 bolts per side.if you do you could check all the looms for breakages etc. Edited October 17, 2013 by buster Quote Link to comment Share on other sites More sharing options...
karlh Posted October 17, 2013 Share Posted October 17, 2013 Matt, The airbag system has two modes - the User Mode and the Diagnosis Mode. You switch back and forth between the two modes using the ignition key procedure you used. Switching to the Diagnosis Mode doesn't clear the light; it lets you identify the problem. In the User Mode the airbag light simply tells you there is a malfunction. Normally the light comes on for 7 seconds when the ignition is first turned on, then goes out. If it blinks after the 7 seconds, as yours does, there is a fault. If it stays on steady, there is a more serious fault, such as an airbag or seat belt tensioner that has deployed. In the Diagnosis Mode the blinking pattern tells you which component is at fault. There are over a dozen blinking patterns, with combinations of long and short on times. The best way to tell which component is faulty is with the Service Manual. I know that UK manuals are virtually impossible to find, but the US manual may help. 1 Quote Link to comment Share on other sites More sharing options...
karlh Posted October 17, 2013 Share Posted October 17, 2013 Matt, Here are the pages from my 2005 Service Manual that describe the airbag modes and blinking patterns. Airbag Diagnosis (2005 350Z).pdf Quote Link to comment Share on other sites More sharing options...
Grundy Posted October 17, 2013 Author Share Posted October 17, 2013 Cheers guys big help on here! I'll take a look on Saturday and see what happens. Thanks for the information guys Quote Link to comment Share on other sites More sharing options...
Floydbax Posted October 17, 2013 Share Posted October 17, 2013 Just as an add on, check you horn!! My airbag warning light has been doing its 'thing' for a while, after checking the seat plugs etc and many resets it was still flashing. Then the other day I went to beep the horn and it wasn't working, so after fiddling around with the wiring in there getting it to work now the reset on the airbag light works, must have been a dodgy connection up there. Quote Link to comment Share on other sites More sharing options...
hensh65 Posted October 18, 2013 Share Posted October 18, 2013 Just as an add on, check you horn!! My airbag warning light has been doing its 'thing' for a while, after checking the seat plugs etc and many resets it was still flashing. Then the other day I went to beep the horn and it wasn't working, so after fiddling around with the wiring in there getting it to work now the reset on the airbag light works, must have been a dodgy connection up there. The airbag warning light is to let you know there is a code in the system, if your horn wasn't working then that would have been the code. 9 times out of 10 though its to do with the wiring under the seat. Quote Link to comment Share on other sites More sharing options...
Grundy Posted October 23, 2013 Author Share Posted October 23, 2013 Funnily enough, after letting her have a sleep that night, started her up in the morning and everything's been fine since. *Touches Wood* Quote Link to comment Share on other sites More sharing options...
pdg32 Posted November 16, 2013 Share Posted November 16, 2013 Glad you sorted it, though I'd get a second opinion if it does come back Quote Link to comment Share on other sites More sharing options...
Grundy Posted November 17, 2013 Author Share Posted November 17, 2013 Glad you sorted it, though I'd get a second opinion if it does come back Back again, for the past 2 weeks! Quote Link to comment Share on other sites More sharing options...
SamN Posted November 17, 2013 Share Posted November 17, 2013 Did you get to the bottom of this mate? I have the light flashing up too now! Tried the ignition thing and it just made it flash slower. Quote Link to comment Share on other sites More sharing options...
Grundy Posted November 18, 2013 Author Share Posted November 18, 2013 Did you get to the bottom of this mate? I have the light flashing up too now! Tried the ignition thing and it just made it flash slower. Nope, mines still going I've read that sometimes it can be caused by things falling under the seat, I.e. passenger drops a lighter, bottle etc. Check that first. Since it's come back on, i've not tried the reset again. Need to try it again. (Btw you the one on the same table as me yesterday? ) Quote Link to comment Share on other sites More sharing options...
SamN Posted November 18, 2013 Share Posted November 18, 2013 This morning mine is off! Winner... Quote Link to comment Share on other sites More sharing options...
