Grundy Posted October 16, 2013 Share Posted October 16, 2013 Hey guys, I've read through a very good guide that someone link me on the forum, will either attempt this tonight or on the weekend... Just wanted to see if anyone has done this job with Mole grips? And is it a Tricky job or a quick 10minute job? Cheers Matt Quote Link to comment Share on other sites More sharing options...
Bems Posted October 16, 2013 Share Posted October 16, 2013 Piece of cake. Just use your hands and unscrew anticlockwise. It a fine thread so take a while to unscrew but its as easy a job as your likely to do on the zed. Nismo is just opposite. Quote Link to comment Share on other sites More sharing options...
Pnthrblkzs Posted October 16, 2013 Share Posted October 16, 2013 Some people (including me) find/found the bond on the standard gear knob difficult to break. Others have been able to remove the standard gear knob by hand. As per the guide be sure to grip the shaft when turning the gear knob so you don't damage the transmission Quote Link to comment Share on other sites More sharing options...
Grundy Posted October 16, 2013 Author Share Posted October 16, 2013 Some people (including me) find/found the bond on the standard gear knob difficult to break. Others have been able to remove the standard gear knob by hand. As per the guide be sure to grip the shaft when turning the gear knob so you don't damage the transmission Yeah the one on it at the moment is worn away and twists quite freely, I still imagine I need to get under the gaiter to finish the job... Quote Link to comment Share on other sites More sharing options...
alexdax Posted October 16, 2013 Share Posted October 16, 2013 its easy Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted October 16, 2013 Share Posted October 16, 2013 When you take the OEM knob off there is a small metal collar at the base of the thread of the shaft. This is to stop you screwing the OEM knob down to far. You must take this OFF before screwing on the Nismo one. If not the Nismo will rattle and pee you off!! 2 Quote Link to comment Share on other sites More sharing options...
Lexx Posted October 16, 2013 Share Posted October 16, 2013 Piece of cake. Just use your hands and unscrew anticlockwise. It a fine thread so take a while to unscrew but its as easy a job as your likely to do on the zed. Nismo is just opposite. You can do damage to the gearbox linkage doing it as simply as that. You must use grips to hold the shaft in place. Wrap gear stick in towel Grup with pliers or mole grips Unscrew the gear knob whilst using some pressure on the mole rips to counter act any torque you are putting onto the shaft. Reverse the procedure when putting on new one and tightening it. 1 Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted October 16, 2013 Share Posted October 16, 2013 (edited) However I strongly suggest you dont grip the gear knob of a 370 like I did when I went to change Sparkies back last year. Unlike the 350 which is a heavy solid lump, the 370 is light and hollow and held on with thread lock. The swan necks crushed it like plastic. Nasty horrid thing. Edited October 16, 2013 by 4RE Leather Quote Link to comment Share on other sites More sharing options...
Grundy Posted October 16, 2013 Author Share Posted October 16, 2013 Piece of cake. Just use your hands and unscrew anticlockwise. It a fine thread so take a while to unscrew but its as easy a job as your likely to do on the zed. Nismo is just opposite. You can do damage to the gearbox linkage doing it as simply as that. You must use grips to hold the shaft in place. Wrap gear stick in towel Grup with pliers or mole grips Unscrew the gear knob whilst using some pressure on the mole rips to counter act any torque you are putting onto the shaft. Reverse the procedure when putting on new one and tightening it. Awesome that's what I was after, I'll do this job on the weekend then, along with removing the Number plate holder Quote Link to comment Share on other sites More sharing options...
Jp606 Posted October 16, 2013 Share Posted October 16, 2013 Really easy to do There's actually a good guide that comes with it in the box. Quote Link to comment Share on other sites More sharing options...
Bems Posted October 16, 2013 Share Posted October 16, 2013 Maybe mine had been off before. The OEM didn't rattle or anything but the was only a light/consistent resistance from start to Finnish, definately not tight enough to do any damage. I have had to use mole grips in the past but not the zeds Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted October 16, 2013 Share Posted October 16, 2013 Maybe mine had been off before. The OEM didn't rattle or anything but the was only a light/consistent resistance from start to Finnish, definately not tight enough to do any damage. I have had to use mole grips in the past but not the zeds OEM isn't designed to rattle!!!! I said that if you leave the collar on and put the Nismo on the Nismo will rattle!!!! Quote Link to comment Share on other sites More sharing options...
Bems Posted October 16, 2013 Share Posted October 16, 2013 Maybe mine had been off before. The OEM didn't rattle or anything but the was only a light/consistent resistance from start to Finnish, definately not tight enough to do any damage. I have had to use mole grips in the past but not the zeds OEM isn't designed to rattle!!!! I said that if you leave the collar on and put the Nismo on the Nismo will rattle!!!! Yep I realise what you said! I was simply stating that mine didn't rattle or vibrate or feel loose to hand even though it seems it was a loose fit going by what most are saying. Quote Link to comment Share on other sites More sharing options...
