HR Y-pipe on DE
pmorg4
Hi guys
I've read lots of threads around the web including here stating that the HR Y-pipe can be bolted straight onto the DE models of 350z, with the possible exception of the RevUp version. However, a member on here is selling an HR pipe but states that it wouldn't fit his DE model.
What is the definitive answer here? I'm thinking of buying the HR pipe to fit to my 2005 DE model - is there any reason it wouldn't fit? I know some owners said they had to remove some plastic aerodynamic aids, and I've no problem doing that if required.
On a related note, are the flexis on the HR any better than those fitted to the DE, or are they similarly doomed to fail in no time?
Thanks!
  • 3 weeks later...
Yes the redesign of the y pipe flows better, as the de pipe is restrictive... something about the longer track more torque or diameters something like that... whereas aftermarket types tend to lose bottom end..im crap at describing stuff like this check here for info..
http://g35driver.com/forums/intake-exhaust/245202-350z-hr-y-pipe-installed-2003-g35.html
