Zed devil Posted October 14, 2013 Share Posted October 14, 2013 (edited) Hey all, My VDC, Slip and Check Engine light all randomly came on today. I stopped the car and started the engine again and the check engine light remained on. I borrowed my friends code reader which showed up as P0350 Ignition Coil Circuit. I cleared the fault and the light went off. Drove the car, parked up, started again an all 3 lights are showing again. Now showing P0350 and P0303 Cylinder 3 misfire. The car sounds and feels a bit "Ropey" now. Could this be spark plugs? If so, seems weird how the VDC an Slip light also came on? Thanks Edited October 14, 2013 by Zed devil Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 15, 2013 Share Posted October 15, 2013 could be battery failing. can do some weird things Quote Link to comment Share on other sites More sharing options...
Zed devil Posted October 15, 2013 Author Share Posted October 15, 2013 Yeah I've seen that on other threads. Could possibly be coil pack? Quote Link to comment Share on other sites More sharing options...
hensh65 Posted October 15, 2013 Share Posted October 15, 2013 Haven't had issues with coil packs on this car but have on previous, normally the enginer note is totally different and you might get a bit of extra vibrations but thats just speculation. Not the worst thing to go wrong with your car tbh, has the spark plugs been changed yet? Quote Link to comment Share on other sites More sharing options...
Darren-B Posted October 15, 2013 Share Posted October 15, 2013 First thing to check is the ground from the ignition circuit, it bolts onto the timing cover @ the front. underneath the engine cover Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted October 15, 2013 Share Posted October 15, 2013 First thing to check is the ground from the ignition circuit, it bolts onto the timing cover @ the front. underneath the engine cover the magic wire!!! Quote Link to comment Share on other sites More sharing options...
Zed devil Posted October 15, 2013 Author Share Posted October 15, 2013 Will check it out. Cleared the fault and it hasn't come back yet. Just a query, when I unplugged coil pack 3, the VDC, Slip and EML all stayed lit up. The code reader picked up the same 2 faults. When I plugged back in and erased codes they didn't come back. However, I spoke to another 350z owner and when they unplugged a coil pack, no lights lit up on the dashboard. When they plugged in a code reader, it only picked up the code P0350 which is ignition coil circuit. Both cars are the same model. Why would one car bring up the fault lights on dash and 2 fault codes but the other car brought up no fault lights and only one code? Quote Link to comment Share on other sites More sharing options...
Ricardo z Posted November 28, 2013 Share Posted November 28, 2013 Hi, I have the P0350 [on JDM 02] and desperate to find the fault. Nissan say they haven't got wiring diagrams for JDM and can't find it. They say coils plugs ok, disconnect delimiter, immobiliser. Still no joy. Anyone help? Lesson is don't buy a JDM.... 1 Quote Link to comment Share on other sites More sharing options...
Ebized Posted November 28, 2013 Share Posted November 28, 2013 Will check it out. Cleared the fault and it hasn't come back yet. Just a query, when I unplugged coil pack 3, the VDC, Slip and EML all stayed lit up. The code reader picked up the same 2 faults. When I plugged back in and erased codes they didn't come back. However, I spoke to another 350z owner and when they unplugged a coil pack, no lights lit up on the dashboard. When they plugged in a code reader, it only picked up the code P0350 which is ignition coil circuit. Both cars are the same model. Why would one car bring up the fault lights on dash and 2 fault codes but the other car brought up no fault lights and only one code? Maybe this vvvvv or did you check it? First thing to check is the ground from the ignition circuit, it bolts onto the timing cover @ the front. underneath the engine cover Quote Link to comment Share on other sites More sharing options...
