orriss Posted October 14, 2013 Share Posted October 14, 2013 Help please, Two days ago I started my car (54 plate) and was greeted with the traction control lights and stability management light were illuminated whilst driving. These lights were on constantly until I turn off the engine then started it again. The following day the car took three attempts to start then engine management light was on along with the same two lights from day before. Used a diagnostic device and fault code p1124 came up. I know this is throttle control relay what I don't know is how to fix. Nissan have said I need a new relay board at 260 plus vat.... Help please..... Quote Link to comment Share on other sites More sharing options...
bamdc2 Posted October 15, 2013 Share Posted October 15, 2013 Assuming the code is correct then I would PM zmanalex for parts as likely cheaper than Nissan. Alex may also be able to give some advice if you talk it through with him. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 15, 2013 Share Posted October 15, 2013 actually you need to pm Clark Motorsports now. All pm's for Alex regarding parts need to go there Quote Link to comment Share on other sites More sharing options...
bamdc2 Posted October 15, 2013 Share Posted October 15, 2013 huh I totally missed that! Thanks Mike Quote Link to comment Share on other sites More sharing options...
orriss Posted October 15, 2013 Author Share Posted October 15, 2013 Should I pm zmanalex for advice or Clark Motorsport? Can't find anyone who has had this fault. The car is now firing up once then dying, when it finally does run the throttle does not work!í ½í¸© Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 15, 2013 Share Posted October 15, 2013 (edited) Orriss, Your Engine Control Module (ECM) has detected that the throttle control motor relay is stuck ON. Power supply for the throttle control motor is provided to the ECM via the throttle control motor relay. The throttle control motor relay ON/OFF is controlled by the ECM. When the ignition switch is turned ON, the ECM sends an ON signal to throttle control motor relay and battery voltage is provided to the ECM. When the ignition switch is turned OFF, the ECM sends an OFF signal to throttle control motor relay and battery voltage is not provided to the ECM. This will explain why you are going onto limp mode. Just because the relay is stuck on does not necessarily mean that the relay is faulty. Possible causes including the relay, could be dirty connections, faulty wiring, or even ECU or IPDM. Alex. Edited October 15, 2013 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
orriss Posted October 15, 2013 Author Share Posted October 15, 2013 Cheers dude, I'm getting on with this tomorrow if the weather is ok. Fingers crossed it just needs a clean up and wd40..... Quote Link to comment Share on other sites More sharing options...
