Aikido2856 Posted October 11, 2013 Share Posted October 11, 2013 Ok peeps I seem to have a sticky window motoris there anything I can do to free it up or does it mean a new motor? Quote Link to comment Share on other sites More sharing options...
KyleR Posted October 11, 2013 Share Posted October 11, 2013 There are one or two other threads about this, try the search and I'm sure you'll find the information that you require Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted October 11, 2013 Share Posted October 11, 2013 New window motors in stock at competitive price if you need one Quote Link to comment Share on other sites More sharing options...
chubbster Posted October 11, 2013 Share Posted October 11, 2013 This is a long shot. Is it worth trying the window reset procedure before doing anything else? 1. Make sure the window is shut. 2. Keep the window button pressed down for 15 seconds. (The window will open) 3. Hold the window button in the 'up' position for 15 seconds. (The window will close) Probably won't solve your problem, but it's worth a minute of your life, just in case. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 14, 2013 Share Posted October 14, 2013 motor is failing so you can refurbish it guide here http://www.350z-uk.c...ttachment-incl/ if still no good you will need to buy an new motor from one of the traders here Quote Link to comment Share on other sites More sharing options...
thorpa520103 Posted October 14, 2013 Share Posted October 14, 2013 I have the same issue and need to buy a new motor for my Import 350z Fairlady anyone know where I can get one from apart from Nissan Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 14, 2013 Share Posted October 14, 2013 I have the same issue and need to buy a new motor for my Import 350z Fairlady anyone know where I can get one from apart from Nissan have you tried the guide above first and refurbish the motor otherwise traders on here that sell them are Clarks Motorsport or Horsham Developments 1 Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted October 14, 2013 Share Posted October 14, 2013 We have them cheaper than Nissan in stock for next day delivery http://www.clarkmotorsport.co.uk/search/window%2Bmotor 1 Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted October 14, 2013 Share Posted October 14, 2013 Might be buying one of those! Time I take it all apart I might as well change the flipping thing. So annoying not being to hear the exhaust Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 15, 2013 Share Posted October 15, 2013 Cheapest option is to remove the motor and clean the commutator and free up the stuck brushes if your competent, usually works. Quote Link to comment Share on other sites More sharing options...
