Stutopia Posted October 8, 2013 Share Posted October 8, 2013 On the way home from work the air bag warning light popped up. I had a quick rustle under the seats, checked everything looked secure, nothing loose, did the reset from here http://www.350z-uk.com/index.php?showtopic=3047 and it went away. However, 5 minutes later it's back on. Grrrrrrr. Any suggestions from here for further fiddling or do I have an actual genuine light I need to go and get looked at? Going to have a proper ratch around after tea, once I've kicked off the suit. What colour leads should I be examining down there? Is it yellow? Thanks anyone. Quote Link to comment Share on other sites More sharing options...
choptop Posted October 8, 2013 Share Posted October 8, 2013 Make sure everything is connected as should be that you can see. Disconnect battery. Leave 5 minutes. Reconnect battery. See if the fault returns again. Quote Link to comment Share on other sites More sharing options...
Stutopia Posted October 8, 2013 Author Share Posted October 8, 2013 Checked them more closely now, all look and feel secure (who knew there were so many?). Disconnected battery. Left her five. Still there. I've reset again and gone, very short drive, not appeared again, left her to think about what she's done overnight. Just out of interest. When the light is on does that mean the system is disarmed? Or likely to explode in my face any second? Quote Link to comment Share on other sites More sharing options...
chubbster Posted October 8, 2013 Share Posted October 8, 2013 I think you'll find it's just disarmed, so no need to drive along with your arm over your face. In the past I've resorted to sticking a little bit of black tape over the flashing light (it's sooooooo annoying, isn't it?). My personal recommendation would be to just keep using the reset procedure (sometimes I've had to do it a few times before it works), which gives you an unpredictable amount of time before the bl00dy thing starts to flash again - and fingers crossed it doesn't start to flash when you're giving a test drive to the bloke who wants to buy it. Quote Link to comment Share on other sites More sharing options...
KyleR Posted October 8, 2013 Share Posted October 8, 2013 I'm pretty sure it'll be a connection somewhere. The yellow parts may be tight but the connection inside them either end may be loose. Try pushing the wires into the connector a bit. Hopefully that'll stop it for a while Quote Link to comment Share on other sites More sharing options...
Stutopia Posted October 8, 2013 Author Share Posted October 8, 2013 Cheers fellas. I've got a friendly tech next door who'll hook it up to his super computer if it comes back on tomorrow. Hopefully that'll at least give me a connector, or area, to check once more. She was in for a lip respray today, you don't think some overspray could've snuck into one of the front impact sensors? I know it's a long shot but... Quote Link to comment Share on other sites More sharing options...
chubbster Posted October 8, 2013 Share Posted October 8, 2013 If your mate pinpoints the problem, let us know, because it's a common issue, not easily solved by wiggling cables. Quote Link to comment Share on other sites More sharing options...
Stutopia Posted October 8, 2013 Author Share Posted October 8, 2013 Of course. Naturally I searched before posting didn't find many actual resolutions. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 9, 2013 Share Posted October 9, 2013 loom in the back of the seat could have a broken wire. I had this issue. Solder and fixed Quote Link to comment Share on other sites More sharing options...
Stutopia Posted October 9, 2013 Author Share Posted October 9, 2013 Something else to think about. Cheers Mike. No sign of it today though Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 10, 2013 Share Posted October 10, 2013 move ya seat and tilt and see if it come back on Quote Link to comment Share on other sites More sharing options...
hensh65 Posted October 10, 2013 Share Posted October 10, 2013 I always find if anyone leaves anything in the footwell (no doubt hits or goes under the seat) it comes one. So I normally just scream at the misses to get her crap in the boot 1 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted October 10, 2013 Author Share Posted October 10, 2013 (edited) I always find if anyone leaves anything in the footwell (no doubt hits or goes under the seat) it comes one. So I normally just scream at the misses to get her crap in the boot I don't really allow passengers as such, they add weight and clutter and think it's appropriate to eat and/or drink inside the car Edited October 10, 2013 by SuperStu 1 Quote Link to comment Share on other sites More sharing options...
dErZ Posted October 10, 2013 Share Posted October 10, 2013 Also reseat it in the SRS unit (you have to remove the armrest housing and its under there) When/if you get the error again, do the key combination and take note of what its telling you is wrong at least then you have an idea which seat or airbag is mucking about. Quote Link to comment Share on other sites More sharing options...
K370Z2 Posted October 12, 2013 Share Posted October 12, 2013 You will not be able to clear this fault as i tried all the above over a 3 week period. Its a common fault on the 350Z & a host of other cars especially when fitted with heated seats as it dries the terminals out. A cheap fix by a decent Auto Electrician cost me £35 Quote Link to comment Share on other sites More sharing options...
chubbster Posted October 13, 2013 Share Posted October 13, 2013 You will not be able to clear this fault as i tried all the above over a 3 week period. Its a common fault on the 350Z & a host of other cars especially when fitted with heated seats as it dries the terminals out. A cheap fix by a decent Auto Electrician cost me £35 what was the cheap fix? Hard wiring the connections under the seats? Quote Link to comment Share on other sites More sharing options...
Stutopia Posted October 18, 2013 Author Share Posted October 18, 2013 Not shown up for a good while now, including the forces of the trackday. Must be fixed FOREVER! Quote Link to comment Share on other sites More sharing options...
timb2010 Posted October 18, 2013 Share Posted October 18, 2013 (edited) Stu if it happens again, you can read the faults from the flashing SrS light. It will tell you exactly which item triggered the light to come on. There's 6 airbags, seat tensioners and the control unit. All have a different sequence of flashes. Check my posts regarding SRS. They will help you to find it and also how to tighten the connection on the yellow wires. On the phone now so can't help much more. Sent from my GT-I9300 using Tapatalk 2 Edited October 18, 2013 by timb2010 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted October 18, 2013 Author Share Posted October 18, 2013 Stu if it happens again, you can read the faults from the flashing SrS light. It will tell you exactly which item triggered the light to come on. There's 6 airbags, seat tensioners and the control unit. All have a different sequence of flashes. Check my posts regarding SRS. They will help you to find it and also how to tighten the connection on the yellow wires. On the phone now so can't help much more. Sent from my GT-I9300 using Tapatalk 2 Nice one, I'll check it out. Quote Link to comment Share on other sites More sharing options...
RedWill Posted October 22, 2013 Share Posted October 22, 2013 Don't forget a airbag light is now an MOT failure! Quote Link to comment Share on other sites More sharing options...
Mctwist Posted October 26, 2013 Share Posted October 26, 2013 (edited) When in self diagnostics mode i'm seeing the 2sec off, 3 sec on repetition. According to the manual: Like the OP's, mine seems to keep returning The "MOT Bible" states: A Supplementary Restraint System (SRS) malfunction indicator lamp: symbol may be displayed. • inoperative • indicating a system malfunction. But this light pattern indicates an old fault and just requires erasing. Is this technically not an MOT fail? (admittedly, i'd love having to explain this to an MOT tester lol) Edited October 26, 2013 by Mctwist Quote Link to comment Share on other sites More sharing options...
RedWill Posted October 27, 2013 Share Posted October 27, 2013 It didn't used to be but was recently added as a failure. My brother in law owns a garage which do MOT tests and told me since March it is a failure. Quote Link to comment Share on other sites More sharing options...
