Briggsybriggs1 Posted October 8, 2013 Share Posted October 8, 2013 Iv got a problem I'm one off the unlucky ones that has got the high oil consumption engine . Iv being checking the USA forums and most off them say new block or an engine rebuild or change Just wanted to no has anyone on here had this problem and fixed it ? or do I just sell it and pass the problem on Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted October 8, 2013 Author Share Posted October 8, 2013 Sorry forgot to say it uses ore than a 1lt per 1000 miles Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 8, 2013 Share Posted October 8, 2013 1 x litre per 1000 miles is common on the rev up. Either live with it or sell it on remembering to disclose the oil consumption issue. Alex. 1 Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted October 8, 2013 Author Share Posted October 8, 2013 It's a Second car and I love my Z so I can live with it :-) .was just hoping some one new a fix for the problem Quote Link to comment Share on other sites More sharing options...
Wasso Posted October 8, 2013 Share Posted October 8, 2013 You e already answered your own question and its the only answer to be honest. I'm consuming the same losses you are on 85k miles. It started to show the issue more so at 70k'ish. Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted October 8, 2013 Author Share Posted October 8, 2013 I no just wish I could fix it and have to check the oil every time I use it . Iv had the car 2 years got it at 38k now it's at 48k iv read there were a lot off problems with this revup model since it's being released . Sent from my iPad using Tapatalk - now Free Quote Link to comment Share on other sites More sharing options...
maddog1982 Posted October 8, 2013 Share Posted October 8, 2013 where does the oil show on the dipstick after a 1000 miles? Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted October 9, 2013 Author Share Posted October 9, 2013 About half way between L and H from being full. Iv got no leaks no smock Quote Link to comment Share on other sites More sharing options...
maddog1982 Posted October 9, 2013 Share Posted October 9, 2013 About half way between L and H from being full. Iv got no leaks no smock CHeers for that, Im new to the Zeds and have a 2007 DE car, so watching mine carefully! Quote Link to comment Share on other sites More sharing options...
chubbster Posted October 9, 2013 Share Posted October 9, 2013 If it's any consolation to you (and it probably isn't) Nissan wouldn't have accepted this as an issue when the car was under warranty. They needed a consumption of at least 2 litres per 1,000 miles before they would recognise it as a problem. Having no visible leaks and no smoke is also normal for these 'oil burners'. The oil just disappears. Zmanalex's comments are spot on. In addition to this, and to further what you've already posted, I was told by an 'insider' who knew a great deal about these cars that the problem can become more severe at any point, so bear this in mind when deciding what to do. My personal recommendation, for what it's worth - sell up and get an MY07 or something. Quote Link to comment Share on other sites More sharing options...
Darren-B Posted October 9, 2013 Share Posted October 9, 2013 1 x litre per 1000 miles is common on the rev up. Either live with it or sell it on remembering to disclose the oil consumption issue. Alex. There's a saying that comes to mind, 'Do what I say, not what I do' Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted October 9, 2013 Share Posted October 9, 2013 In that case revup cars should be fitted with Miles per Litre of Oil gauges... 1 Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted October 9, 2013 Share Posted October 9, 2013 In that case revup cars should be fitted with Miles per Litre of Oil gauges... Another saying, pot & kettle comes to mind Sent from the Jaaaaaag at the golf club YAAAARRRRRRRPPPPPPPPPP 1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted October 9, 2013 Share Posted October 9, 2013 In that case revup cars should be fitted with Miles per Litre of Oil gauges... So what was wrong with yours then being pre revup Quote Link to comment Share on other sites More sharing options...
SteveM Posted October 9, 2013 Share Posted October 9, 2013 i am sure i read on here somewhere that different oils gave different levels of consuption??? i will go have a look Quote Link to comment Share on other sites More sharing options...
SteveM Posted October 9, 2013 Share Posted October 9, 2013 ok it was Nielp but i cant remeber what oil he says he used that reduced oil usage.. maybe a PM to him? Quote Link to comment Share on other sites More sharing options...
SteveM Posted October 9, 2013 Share Posted October 9, 2013 ok found it Fuchs Titan race pro might be worth a try and see if it helps? Quote Link to comment Share on other sites More sharing options...
Neilp Posted October 9, 2013 Share Posted October 9, 2013 Changing to a better quality of oil helps. I think jez from Horsham developments changed the grade he was using to slow the usage on his. Quote Link to comment Share on other sites More sharing options...
Neilp Posted October 9, 2013 Share Posted October 9, 2013 May I add I wasn't using much before I changed. Quote Link to comment Share on other sites More sharing options...
Wasso Posted October 9, 2013 Share Posted October 9, 2013 Also Jez fitted an oil cooler. I tried the Titan and it did feck all. Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted October 9, 2013 Author Share Posted October 9, 2013 Thanks everyone for your advice will take if all in. Think I might do the oil change with the better oil and run it for a bit to check what it's like and if it's not changed anything I will trade it back to evens halshaw were I got it from simples ! I was really after modding the car and it don't want to spend££££ and then it blow up? Sent from my iPad using Tapatalk - now Free Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted October 9, 2013 Author Share Posted October 9, 2013 ok found it Fuchs Titan race pro might be worth a try and see if it helps? Is the oil 5w40 mate or was it the thicker stuff 10w 40? Sent from my iPad using Tapatalk - now Free Quote Link to comment Share on other sites More sharing options...
glrnet Posted October 9, 2013 Share Posted October 9, 2013 Also Jez fitted an oil cooler. I tried the Titan and it did fuchs all. Fixed that for you 1 Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted October 9, 2013 Share Posted October 9, 2013 Also Jez fitted an oil cooler. I tried the Titan and it did fuchs all. Fixed that for you Oil 2nd that Sent from the Jaaaaaag at the golf club YAAAARRRRRRRPPPPPPPPPP Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted October 9, 2013 Share Posted October 9, 2013 Heavy oil consumption was the only reason I traded my Zed ... for a new Polo for wifey Quote Link to comment Share on other sites More sharing options...
