Suspension and Geo set up
Ceejay29
Hi Guys,
Need a bit of help. I want to set up the suspension on the zed properly, I have a feeling it is all over the place, for instance I have adjusted the ride height myself and I imagine the previous owner has done too. Yikes!!
It has been dropped on coilovers, we have switched the oem drop links with adjustable ones and I have purchased poly bushes for the front and rear arms. I have recently bought front adjustable camber arms and will be buying a set up for the rear, beit a camber arm kit or toe and bolt kit (not sure what to go for as I do not fully understand the difference between the two.)
I use the car as a weekend toy really and would like a fast road set up. What else would I need to upgrade, sway bars? and could anybody recommend a specialist that would be able to set this lot up for me within proximity to Bath/Bristol.
Any information or advice would be greatly appreciated.
You'll need the camber arm and bolt kit for the rear, most of us go for the eibach/spc one which is about £175 from cs, Tarmac and Zmanalex. Also a set of eibach arb's from the above traders would b a great upgrade from what I've heard, but yet to get a set myself.
^^^ That is all you'll need for the rear end, comes with the toe bolt as you can see. However, I would suggest trying to get hold of some second hand OEM camber bolts just incase you have to cut yours off, they get corroded on pretty hard sometimes.
