paulashy Posted October 2, 2013 Share Posted October 2, 2013 (edited) r Edited November 25, 2013 by paulashy Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted October 2, 2013 Share Posted October 2, 2013 Did you check the wheel nuts after you had the brake pads changed? Ie a few days later in case they need tightening up! It is not unheard of for them to loosen silghtly after being taken off/refitted. If a wheel comes loose even a fraction it will be noticable when braking, especially hard. It is a requirement of bus/coach and truck companies to tighten the wheel nuts after 50kilometer run. The last 2 occasions I have had my wheels off I found a couple of days later that they needed nipping up. Just a thought and to add this is not always the case just some times this can and has happened. Quote Link to comment Share on other sites More sharing options...
