Knocking from front over small bumps
colindalton
thanks - I have the upgraded drop links installed and its only off the lift - the guys cant find anytihng wrong! - they said that there was a little play in the end of the arm? but drive on! - the knocking is driving me mad I need to sort it - in your expierence do you think it sounds like the bushings? if so should i change both sides?
if your guys know what they are doing and they can not find any thing wrong then it will be the ball joint in the compression rod.
These can show no signs of movement but still knock.
New genuine Nissan compression rods are in stock and good to go same/next day.
Just drop me PM if I can help further.
Alex. :)
