Brembo's Pads, Brakes !
M350ZB
  • Replies 67
  • Created
  • Last Reply
Top Posters In This Topic
Thanks sinbad, so the pads are not brembo's then jsut the disks or ?
No problem but you should really use the search function, this topic has been covered loads of times. But to answer your question, Brembo is the make of Brakes (Calipers) Just the gold bits you see, the disk's and pads are standard Nissan items.
Although the Brembo's are good, Upgrading the brakes is still meant to be one of the best mods you can do to the car. If your just planning on replacing the pads, then go for Redstuff or Ferodo, they can usually work out cheaper and they perform better than the OEM items too.
What brakes are you using s1144
You mean Craig now... shes gone man :byebye:
?? :headhurt:
Anyway, Sl114 isn't using any brakes at the moment except the ones on his pushbike as he has just sold his car. AndyC i think has the standard setup like you apart from having Redstuff brake pads.
£100 is for both front and back pads. If buying seperately, fronts are about £55 and £55 for rears.
my Z is in for its third year service + MOT today.
they just called and said i needed new front pads (fair enough for 25k miles old) and quoted £170 for the pair in fitting.
:scare:
i said go ahead then read some of the prices on here. what shall i do - might be able to call and stop them?
:scare:
Tell 'em they are taking the p1ss
:scare:
:angry: yep i think they are.
how much should fitting add on to the cost though?
Even I fitted my current set, its easy peasy :blush:
So did they charge you £170 for the pads and then £63+ VAT for the labour?
nope it was £170 all in. so they charged approx £100 for two pads.
i'm still a mug! at least i know for next time! :blush:
EBC redstuff are £99 for a full car set.
Ferodo DS2500 £185 for a full car set.
No comparison between the two, although the EBC are better than standard the DS2500 are in a different league altogether.
These prices include delivery.
