andybp Posted September 24, 2014 Share Posted September 24, 2014 On 24/09/2014 at 14:17, Ekona said: On 24/09/2014 at 13:13, docwra said: [And despite not actually disagreeing with you since we last discussed mixed tyres, youre wide of the mark on the lag as well - even in 8ft of boost pipe theres not very much air, and its not like youre filling a vacuum either, youre just pushing along whats in the pipe already. See here: I can only go off my own experience, which was changing an air to air intercooled system to a water to air one, which involved removed about a metre of pipework. Throttle response was massively increased, even on a small system like that. You're not just pushing along what's in the pipe, you're compressing it. To compress it means that you have to add more into the same size space, which if the pump (turbo) size doesn't change then it must take longer. Whilst a rear mounted turbo may well be acceptable for people coming from big turbos who are used to having large boost thresholds, they're just not for me. Each to their own though, as always What's that middle car? That looks amazing! technically rear mounts may be laggy and if you were relying on the turbo ie on a small engined car i think it would be crap but on the 350z it feels pretty smooth no kick in the back Quote Link to comment Share on other sites More sharing options...
docwra Posted September 24, 2014 Share Posted September 24, 2014 On 24/09/2014 at 14:17, Ekona said: I can only go off my own experience, which was changing an air to air intercooled system to a water to air one, which involved removed about a metre of pipework. Throttle response was massively increased, even on a small system like that. I know its counterintuitive but every rear mount setup Ive read about has said the same thing, no noticeable increase in lag. And the middle car is a Mustang but sadly I cant find out much more about it, I know STS make quite a few kits so I guess it must be popular in the states 1 Quote Link to comment Share on other sites More sharing options...
andlid Posted September 24, 2014 Share Posted September 24, 2014 Ekona is talking about lag... not noticeable lag Quote Link to comment Share on other sites More sharing options...
andybp Posted September 24, 2014 Share Posted September 24, 2014 On 24/09/2014 at 18:26, andlid said: Ekona is talking about lag... not noticeable lag without a doubt rear mount is going to have more lag than a conventional setup but it doesn't seem to have the all or nothing feel of conventional laggy systems so unless your playing top trumpsin the real world rear mount setups aren't bad Quote Link to comment Share on other sites More sharing options...
andlid Posted September 26, 2014 Share Posted September 26, 2014 My tubo setup has lag to ... not that I notice but it is there... Quote Link to comment Share on other sites More sharing options...
Ekona Posted September 26, 2014 Share Posted September 26, 2014 Probably a good idea to say that I do mean lag, and not threshold. They don't always go hand in hand! My own turbo on the MR2 has a relatively low threshold, and is mapped so that the boost increases the further up the rev range you go. Starts at wastegate, then up to 8psi, then 10psi at the top end. Gives a real rush of power throughout, and also it means that it's not having to wait until 10psi is made all the way down when the compressor is barely spinning. 1 Quote Link to comment Share on other sites More sharing options...
andlid Posted September 26, 2014 Share Posted September 26, 2014 mine is full boost as soon as possible (2500 rpm) lets off boost at the higher rev range due to the springs in the actuator not able to hold the boost. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted January 26, 2015 Share Posted January 26, 2015 (edited) Accidentally found the STS rear mounted turbo whilst looking for something on youtube (this guy has a bunch of them uploaded): https://www.youtube....arch?query=350z I'm sure you guys have seen them anyway but I didn't even know you could have turbo's mounted in your butt I imagine it's cheaper to purchase compared to supercharging, I've no idea just looks less complicated with fewer parts (fewer bits, cheaper right ? ). Ah didn't see this thread either: http://www.350z-uk.com/topic/78039-diy-rear-mount/ Edited January 26, 2015 by RobPhoboS Quote Link to comment Share on other sites More sharing options...
