ABS Light & TCS Lights on
sfield21
On my way home from work it became apparent my ABS and traction control preferred to not work, After turning the car off in traffic and then back on it seemed to go but once I applied the brakes when moving again it came back on.
Getting home with the thoughts of big bills ahead with ABS pumps and sensors being changed etc etc I disconnected the cables from the ABS pump and cleaned the terminals out on each cable with compressed air, Miraculously this seems to have cured the problem with a quick blast round the block to partially proof test it with some brakes tests ensuring the ABS pump worked.
Just curious to see whether to see if anyone else has experienced this and if so how did you come to solution?
:teeth:
