Brighton 350z..
Hello,
Are there any knowledgeable Z owners near Brighton who could help confirm a diagnosis from Zmanlex... As the garage near me can't confirm and I'm struggling to get time to take it elsewhere!
There is a clunking from the passenger side front wheeI when going over bumps and when coming to standstill when braking - which the garage thinks is the suspension top mount (suspension replaced by Abbey in February), Alex's comments were:
"doubt if it will be the top mount, however I can not give you an informed diagnoses without the car being physical.
However, the normal culprits for the noise that you describe are the compression rod bushings or the compression rod ball joints"
If anyone is local and I could swing past I would appreciate it.
Cheers
John
