gareth29 Posted September 22, 2013 Share Posted September 22, 2013 Been reading some related posts recently and realised that I may have created a problem for myself. The motor was idling at very low rpm so I embarked on a throttle body and MAF clean. Now for some confessions: - I didnt disconnect the battery - I moved the butterfly, as far as it would go - a few times (now I read this is a big no no) The clean lifted the idle speed to a pleasant 800 or so, usually, but very often its idling at 1500 and hanging on to revs when changing gear. All this makes for jerky, frustrating progress at times. After the clean I did all the idle air/closed throttle posn resets, then the pedal dance, but never got the cel to blink. Can anyone offer any suggestions? Quote Link to comment Share on other sites More sharing options...
Hooch Posted September 22, 2013 Share Posted September 22, 2013 Keep trying the pedal dance, its all about timing. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted September 25, 2013 Share Posted September 25, 2013 Yep, pure timing. Took me 3 attempts I think to do the idle relearn procedure try having a piece of paper with instructions on it in1 hand and a watch with a second hand in the other. Timing is very critical! Quote Link to comment Share on other sites More sharing options...
longsh07 Posted September 25, 2013 Share Posted September 25, 2013 (edited) Having had a similar issue recently I cleaned (and moved but not very much) the butterfly. Since then I have noticed that when moving the car idles at about 1500 on gear change but as soon as you drop below about 5mph it goes down to 800 with the AC on and 700 with it off. Thinking its meant to do this as it always behaves the same, cant say I ever paid it any attention before cleaning. Can anyone else confirm theirs does the 1500 idle while moving with the clutch down? Edit: By the way cant say this 1500 has ever caused me any issues if its not meant to do that lol Edited September 25, 2013 by longsh07 Quote Link to comment Share on other sites More sharing options...
gareth29 Posted September 27, 2013 Author Share Posted September 27, 2013 thanks, will try it again tomorrow - i have done it successfully before. The problem with the revs not dropping below 1500 is that you cant simply lift off to slow down (depending what gear youre in) you have to declutch - this is around town and going slowly mostly. The revs should drop quickly to idle no matter what speed youre doing. Does any one know what the effect of moving the butterfly is? - should i disconnect the battery before doing the pedal dance? Does an uprev help with this type of thing? Quote Link to comment Share on other sites More sharing options...
gareth29 Posted September 27, 2013 Author Share Posted September 27, 2013 just looked at a youtube video - "24 hour battery reset and idle air relearn 350z 2007 nissan" - now worried i might need a new ecu Quote Link to comment Share on other sites More sharing options...
Dblock Posted September 28, 2013 Share Posted September 28, 2013 just looked at a youtube video - "24 hour battery reset and idle air relearn 350z 2007 nissan" - now worried i might need a new ecu LOL, stop your panicing. Honestly you will be able to sort it out your just not doing it right. First time I did it, it took me about 2hours Where are you as I or a nearby member may be able to pop up and help you Quote Link to comment Share on other sites More sharing options...
chubbster Posted September 28, 2013 Share Posted September 28, 2013 Damn, damn, damn, damn, damn. Every time I glance at the title to this thread I think it says, "Eric Idle" and it REALLY annoys me. Hope I haven't put this worm into anyone else's head. Quote Link to comment Share on other sites More sharing options...
Dblock Posted September 28, 2013 Share Posted September 28, 2013 Damn, damn, damn, damn, damn. Every time I glance at the title to this thread I think it says, "Eric Idle" and it REALLY annoys me. Hope I haven't put this worm into anyone else's head. Off topic. Quote Link to comment Share on other sites More sharing options...
glrnet Posted September 28, 2013 Share Posted September 28, 2013 Lighten up Blocky Quote Link to comment Share on other sites More sharing options...
gareth29 Posted September 28, 2013 Author Share Posted September 28, 2013 Thanks for all the help - took me about 10 goes in the end! For something so simple it has the capacity to really go awry - got it all done a couple of times at least, then disaster - revved the engine during the 20 sec idle period!!, another effort ended when i forgot to dip the clutch and was wondering why it wouldnt start! Anyway it seems tons better, idling at 800 with ac on and no problems during my test drive - no flaring of revs when declutching, much smoother tooling around the village - so hopefully i havent fried the ecu! Right, just the oil leak to sort, drivers seat to refurb, front wings to polish........ 1 Quote Link to comment Share on other sites More sharing options...
Dblock Posted September 28, 2013 Share Posted September 28, 2013 Thanks for all the help - took me about 10 goes in the end! For something so simple it has the capacity to really go awry - got it all done a couple of times at least, then disaster - revved the engine during the 20 sec idle period!!, another effort ended when i forgot to dip the clutch and was wondering why it wouldnt start! Anyway it seems tons better, idling at 800 with ac on and no problems during my test drive - no flaring of revs when declutching, much smoother tooling around the village - so hopefully i havent fried the ecu! Right, just the oil leak to sort, drivers seat to refurb, front wings to polish........ You car wouldn't do anything if you had fried it. Your good to go Quote Link to comment Share on other sites More sharing options...
Dblock Posted September 28, 2013 Share Posted September 28, 2013 Lighten up Blocky Honestly mate, I'm the happiest guy out there. Just people say one thing and then do the same thing themselves. Quote Link to comment Share on other sites More sharing options...
glrnet Posted September 28, 2013 Share Posted September 28, 2013 Sounds like I missed something! Sorry. Sent from my Zed using Nangkang tyres front, RE040's rear Quote Link to comment Share on other sites More sharing options...
Dblock Posted September 28, 2013 Share Posted September 28, 2013 Sounds like I missed something! Sorry. Sent from my Zed using Nangkang tyres front, RE040's rear It's nothing lol. I like your sig, I bet Dan does too Quote Link to comment Share on other sites More sharing options...
chubbster Posted September 29, 2013 Share Posted September 29, 2013 Lighten up Blocky Honestly mate, I'm the happiest guy out there. Just people say one thing and then do the same thing themselves. Sorry if I've upset you - and apologies, especially to the OP for making an off-topic post. I was just trying to be a bit amusing - stupid really. I'll try to avoid doing it again. Quote Link to comment Share on other sites More sharing options...
Dblock Posted September 29, 2013 Share Posted September 29, 2013 Lighten up Blocky Honestly mate, I'm the happiest guy out there. Just people say one thing and then do the same thing themselves. Sorry if I've upset you - and apologies, especially to the OP for making an off-topic post. I was just trying to be a bit amusing - stupid really. I'll try to avoid doing it again. Don't be silly. Just having some banter. Quote Link to comment Share on other sites More sharing options...
longsh07 Posted September 30, 2013 Share Posted September 30, 2013 Decided to give this and the other throttle related resets ago and funnily enough it does feel considerably smoother. No more hanging at 1500 when clutching. Also just for you Chubbs Quote Link to comment Share on other sites More sharing options...
glrnet Posted October 26, 2013 Share Posted October 26, 2013 Sounds like I missed something! Sorry. Sent from my Zed using Nangkang tyres front, RE040's rear It's nothing lol. I like your sig, I bet Dan does too I wrote it for Dan Quote Link to comment Share on other sites More sharing options...
