Changing interior lights to LED, blown fuse? what fuse?
EvansJD2112
So, bought a couple of LED bulbs to replace the interior ones as a 'quick' upgrade.
Popped out this morning, removed the cover and replaced the bulbs. couple of mins max.
Now, neither the interior lights nor the mirror lights work.
OK, must have blown a fuse I thought..
Popped off the fuse cover, located what I thought was the right one, took it out and it looked fine.
Turned on the ignition and the radio/satnav didnt come on.
Weird..
Popped the fuse back in and radio comes on again.
So, is the diagram on the back of the fuse box cover completely wrong?
Where is the fuse for the interior/mirror lights?
I have a copy of the maintenance manuals, and the fuse block looks right in this diagram
Just doesnt say what each one does!
Much appreciate any help.
Maybe it's not a fuse and that other thing that can blow that I can never remember the name of and can be costly to fix?
Hopefully someone will be along shortly to advise you better than I can :thumbs:
BCM. but I doubt its that seeing as they don't work at all. Normally a busted lights section in the BCM just kills the auto on-off dome lights facility.
Secret fuse box by the battery perhaps?
Just got to the fuse box behind the battery (great location!)
Nothing obvious from what I can make out on the diagram
Anyone got a list of what all the fuses actually link to?
BTW, noticed the boot light is out too, so all interior lights
Defo sounds like a fuse to me....
Located the fuse, its No18 in the box by the accelerator
Replaced it and the left hand side LED worked for a second, and then pop; fuse gone again.
Put the old bulbs back in, and another fuse, and I have a working left hand side map light but the right hand one isnt.
(swapped bulbs around to confirm this)
Left hand one works as it should, either by switch or by the door.
Any idea why the right hand one is dead?
@Beavis - maybe me being stupid here, LED lamps have a wrong/right way of installing?
Make sure your not using LED bulbs with the heat shield on the rear as it will short and blow a track on your BCM, this will then have to have a wire soldered on to sort it.
Bad: http://www.ebay.co.uk/itm/39mm-3-SMD-5050-Pure-White-Dome-Festoon-CANBUS-OBC-No-Error-Car-3-LED-Light-Bulb-/330928707508?pt=UK_Motorcycle_Parts&hash=item4d0ce357b4
I used these and work perfect with a lovely white light:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=281052978818&ssPageName=ADME:L:OC:GB:3160
On the way to work this morning, the right hand side map light came on after about 10mins driving.
Stayed on for about 2-3 seconds and then died again!
I have no idea what this could be
From the wiring diagram, if one light works the other should do to
Bad: http://www.ebay.co.u...=item4d0ce357b4
http://cgi.ebay.co.u...ME:L:OC:GB:3160
Phew..!! I just ordered some from eBay..fortunately I have ordered the correct ones...Didn't know about the heat shield problem. .. :thumbs:
Managed to get hold of a replacement unit off eBay and ordered some proper bulbs to go in it.
So, anyone else who is daft enough to do the same; I'll have a spare switch!
So it was the switch then ?
How did you get the covers off the interior lights do the whole unit come out of the car roof including the sunglasses case. ? :teeth:
Surprisingly easy.
Insert a small screwdriver into the surround of the map light unit.
There are 4 clips, 2 on each side.
The unit then just pops out and is connected via the usual 350z plug type.
The switches themselves just push on/pull off.
