OBD2 Reader?
Zed devil
I got one of these as I thought it was a bit more fun than a straight code reader. Works over wi-fi rather than BT, the link can drop to my iphone after about 5-10 mins from time to time, but works plenty long enough to view fault codes. However, not had a real chance to test it in anger as I've not had any fault codes yet.
http://iobd2.co.uk/
I bought one of the cheap and cheerful readers like the second one listed and was very dissapointed with it..... I then got this Texa OBD.......http://www.texa.co.uk/prodotti_dett.asp?sez=dett&id=22
And this has worked on everything so far and the info it gives is fantastic....... Have a read of the Tech spec on the website.......
Cheers,
Does that work with JDM?
Thanks
Like I said the one I have works fine and clears faults and reads logged faults, for £14 posted its worth a punt on JDM's.
http://www.amazon.co...3&keywords=obd2
Why is it worth a punt. It wont work with a jdm.
No one said previously it wouldn't work with a JDM. If someone has posted that I wouldn't have said it was worth a punt?
Sorry I think you misunderstand me. It won't work with JDM because UK cars use OBD2. Japanese imports don't use this system they use JOBD. Now JODB and OBD2 don't speak to each other. I have many readers at home but only my JOBD reader will read the imports code.
  • 3 weeks later...
