Map Lights Problem from Italy
Alessio
:) hello friends,
I got a 2005 350z Lev.1
Times ago i was changing the interior dome lights from halo to led,
Well, i made some short there.
Changed the fuse, and i noticed that the dome lights now works only in manual way (by clicking) even if the switch is in "door" mode.
Well, i read tooons of post about it.
Lot of people fixed it in different ways, here's what i tried without success.
1 - Check all the fuse in all the fuse box. everything's good.
2 - Unplug the battery for 10 miuntes
3 - Unplug the bcm for 10 minutes
4 - Ecu manual reset procedure
Some tips?
Thanks,
Alessio ;)
