KosmiK Posted September 16, 2013 Share Posted September 16, 2013 Hi all, Damaged my wheel on a pothole on the weekend. Still drivable but needs looking at. Got to drop the wheel off on its own and wanted to double check I'll be ok to use my spare. Current front tyres are 245/30r20 and I think the spare is xxx/80r17. Will this be ok to use for a couple of journeys, if I stick to 50? Thanks Quote Link to comment Share on other sites More sharing options...
lolzz Posted September 16, 2013 Share Posted September 16, 2013 (edited) I think it shouldn't be a problem since it is the front tire. If it was the rear one, than you should be more careful about it.. Edited September 16, 2013 by lolzz Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted September 16, 2013 Share Posted September 16, 2013 Tyre size calculators will help but you'll need to know all 3 measurements for the spare to get it right. The standard spare is a 145/90/16 which I can't check properly as most calculators stop at 85. But at 85 the difference is only 2mm, so if your spare corresponds to that you'll be fine. Get the measurements and go here: http://www.etyres.co.uk/tyre-size-calculator Quote Link to comment Share on other sites More sharing options...
KyleR Posted September 16, 2013 Share Posted September 16, 2013 If the rubber on your 20s is chosen to be as close to OEM size tyres then you'll be fine Quote Link to comment Share on other sites More sharing options...
KosmiK Posted September 16, 2013 Author Share Posted September 16, 2013 Just rechecked the spare, it's 155/80r17. Which using the calculator gives me 3.82% or 25mm increase over my current wheels. Id only need to use it for less than 20 miles so would this be OK? Quote Link to comment Share on other sites More sharing options...
peteman35 Posted September 16, 2013 Share Posted September 16, 2013 (edited) Will be fine. Just go easy on it Edited September 16, 2013 by peteman35 Quote Link to comment Share on other sites More sharing options...
