3sjr Posted September 12, 2013 Share Posted September 12, 2013 So I have just bought some second hand mono pros. all fitted on lovely, the front gave a lovely drop and adjust nicely. However the rears I have bottomed out on the thread meaning I have put them as low as possible and its pretty much standard ride height ? Anyone else have these and have I done something wrong or being silly? Quote Link to comment Share on other sites More sharing options...
BillyZed Posted September 12, 2013 Share Posted September 12, 2013 That's what the other holes were drilled for, the holes higher up towards the mount are the ones to go for. I had the same issue with mine so did the same thing Quote Link to comment Share on other sites More sharing options...
3sjr Posted September 12, 2013 Author Share Posted September 12, 2013 Only thing is the holes are drilled completely wrong :/ They won't line up with the bolt as they have been drilled too high up so it won't sit on the control arm enough to get the bolt through. Also too close to the original holes for me to drill any others. Quote Link to comment Share on other sites More sharing options...
3sjr Posted September 12, 2013 Author Share Posted September 12, 2013 I can take pics if it would help to explain what I'm on about. But the rears are pretty much useless to me now Quote Link to comment Share on other sites More sharing options...
peteman35 Posted September 12, 2013 Share Posted September 12, 2013 Mounts been unscrewed and put on upside down? Quote Link to comment Share on other sites More sharing options...
BillyZed Posted September 12, 2013 Share Posted September 12, 2013 I had to grind my control arm to get them to fit mine were drilled by the same person at the same time so they will fit, they have also been on another 350 like that Quote Link to comment Share on other sites More sharing options...
3sjr Posted September 12, 2013 Author Share Posted September 12, 2013 Aaa okay then I shall try that, if that fails the threads are getting cut Quote Link to comment Share on other sites More sharing options...
BillyZed Posted September 12, 2013 Share Posted September 12, 2013 I just used a grinder and just took like 1mm off the control arm and the mount went right on Quote Link to comment Share on other sites More sharing options...
BillyZed Posted September 12, 2013 Share Posted September 12, 2013 (edited) Then had to raise it up as it was too low then The thread I mean* Edited September 12, 2013 by BillyZed Quote Link to comment Share on other sites More sharing options...
gsexr Posted September 12, 2013 Share Posted September 12, 2013 Got to say that it all sounds a bit dodgy to me. Lets hope drilling/grinding and so on to make them fit doesn`t weaken the mounting points. Just saying that to make you aware. If they were correct for the car they would bolt straight on and not require a chav type adjustment to fit. It will look nice and low if it snaps off at the mount Quote Link to comment Share on other sites More sharing options...
BillyZed Posted September 12, 2013 Share Posted September 12, 2013 On 12/09/2013 at 12:13, gsexr said: Got to say that it all sounds a bit dodgy to me. Lets hope drilling/grinding and so on to make them fit doesn`t weaken the mounting points. Just saying that to make you aware. If they were correct for the car they would bolt straight on and not require a chav type adjustment to fit. It will look nice and low if it snaps off at the mount It's fine as the new holes just replace the existing holes making them redundant, I've been running them for over 6 months The original holes are way to low on the mount which means you can't go away lower than stock height which is pointless Quote Link to comment Share on other sites More sharing options...
KyleR Posted September 12, 2013 Share Posted September 12, 2013 So tip of the day "don't buy HSD Monopro coilovers as the rears don't provide any drop." Good to know as they were on my list of possibilities, just BC and Meisters left. Quote Link to comment Share on other sites More sharing options...
BillyZed Posted September 12, 2013 Share Posted September 12, 2013 On 12/09/2013 at 12:35, KyleR said: So tip of the day "don't buy HSD Monopro coilovers as the rears don't provide any drop." Good to know as they were on my list of possibilities, just BC and Meisters left. Yeah avoid them to be honest, was annoying when I put the rears on and couldn't go any lower! Quote Link to comment Share on other sites More sharing options...
KyleR Posted September 12, 2013 Share Posted September 12, 2013 It's a shame really, the specs are pretty good and the price is attractive. Quote Link to comment Share on other sites More sharing options...
BillyZed Posted September 12, 2013 Share Posted September 12, 2013 There's cheaper HSDs for around £550 new from driftworks, they would be better Quote Link to comment Share on other sites More sharing options...
MeisterR Posted September 16, 2013 Share Posted September 16, 2013 Well, I haven't had any complain about ride height adjustments on the Zeta-S (OEM in-board springs design) or the Zeta-R (True Coilovers rear design). i also think the MeisterR are slightly cheaper with the 10% member discount. Jerrick Quote Link to comment Share on other sites More sharing options...
BillyZed Posted September 21, 2013 Share Posted September 21, 2013 did you sort it mate? Quote Link to comment Share on other sites More sharing options...
dougie350 Posted January 1, 2015 Share Posted January 1, 2015 how much lower can you get them to go by drilling extra holes then? Quote Link to comment Share on other sites More sharing options...
KyleR Posted January 2, 2015 Share Posted January 2, 2015 On 01/01/2015 at 16:28, dougie350 said: how much lower can you get them to go by drilling extra holes then? Depends where you drill the holes. Quote Link to comment Share on other sites More sharing options...
Vlad Posted January 4, 2015 Share Posted January 4, 2015 (edited) There are 3 rings under the spring...1 used to adjust spring pre-load etc and other 2 to secure it.... If you want it dropped - removed 2 bottom rings as 1st ring will be all the way down and wil be secured by the weight of the car. It been suggested to me by driftworks and I had it like that for 2 years when I had my HSDs. Here's a pic how mine used to sit with just one of them rings instead of 3. Edited January 4, 2015 by Vlad Quote Link to comment Share on other sites More sharing options...
Vlad Posted January 4, 2015 Share Posted January 4, 2015 (edited) Double post Edited January 4, 2015 by Vlad Quote Link to comment Share on other sites More sharing options...
