drfeelgood73 Posted September 8, 2013 Share Posted September 8, 2013 Had a bit of a weird situation this morning?... Got into the car, ignition on.... Went to start and all power completely cut out on turn of the key... Absolutely nothing..... Totally void of any electron flow anywhere..... So there i sat wondering how to get out without knack wring the window...... Meanwhile doing random presses of the key fob buttons as well as trying ignition again..... Zip...zilch and nada... Went to pop the boot with the manual release when all of a sudden everything came back on with clunks and clicks...... The most noticeable being whirring and winding From the centre console area...as if changing over a cd in the unit..... Car started no problem after that, and has not occurred again.... The only thing I can think I did was leave the ignition on for about a minute or two before going to start her up as I was turning the Bluetooth on the phone on. Wondered if it could be the key fob battery or the chip playing up and immobilising the car. ...??? Any ideas from anybody???? Quote Link to comment Share on other sites More sharing options...
tony.r123 Posted September 8, 2013 Share Posted September 8, 2013 (edited) Bad conection on the battery? clean terminals and check there tight Edited September 8, 2013 by tony.r123 Quote Link to comment Share on other sites More sharing options...
drfeelgood73 Posted September 10, 2013 Author Share Posted September 10, 2013 Spot on Tony...... Although tightened....when forced by hand the clamp would slip....the band was unable to tighten any more on the terminal...Clamp replaced ...... Quote Link to comment Share on other sites More sharing options...
