Subwoofer
Hooch
Just wondering if it would be a good idea to replace the standard sub woofer with a shallow mount sub?
Something like this: http://www.caraudiocentre.co.uk/product_m-ts-sw2501s4_p-27130.htm?id=pla&gclid=CLb-iaupvLkCFbLMtAodw08AYA
I know the bottle neck is at the amp but would be interested to see if it would make much of a difference?
if you want to run off the bose amp you will need a 0.5 ohm load or you wont drive a 4 ohm sub very well. I got around this by using an impedance adjuster or you would probably have to find a dual 1 ohm sub.
After doing that i fitted the sub onto the metal bracket and found it wasnt solid enough when i started turning it up, so i ended up removing the bracket altogether and pushing a box into the space. hth
Edited by flamez
